new 347 dyno #'s - Ford Mustang Forums : Corral.net Mustang Forum
Old 06-30-2012, 02:59 AM   #1
94_cobRa's Avatar
Trader Feedback: (71)
new 347 dyno #'s
Put the mustang back on the rollers today. Had some breakup in the upper rpms. Gunna swap dist. out to try and fix the issue. Thanks to Willie @Dirtydirtyracing , Nate @ All out performance Fresno, and Ed Curtis @ FTI for all the help.
Air/fuel right at 12.9-13 on wideband
347 stock block
rhs 215
FTI Max Air
Victor EFI
1 3/4 lt's - 2.5" h - flowmasters dumped
80mm TB - homemade intake
All motor & 50 shot #'s . Smooth until 6300 then breakup.
__________________
stock block 94 Cobra pump gas 9.2:1 347, RHS 215 , Victor EFI, FTI NA cam, 80mm Fox TB, 4" Intake, SCT 2400 MAF, 42lb injectors, 1 3/4 Lt's/3" exh, stock T5, & Ford 9" 4.11 - 429whp/400tq
10.7@127 - 1.49 60ft.
94_cobRa is offline
Old 06-30-2012, 03:31 PM   #2
Looks good was the air/fuel on the dyno not working
__________________
SCT certified / Delta Force / Diablosport Ford CMR / Moates / On3 Performance Dealer and Tuner
Dynocom Loaded Chassis Dyno on site
WE DO QUALITY , not QUANTITY
93GRNLX is offline
Old 06-30-2012, 04:08 PM   #3
94_cobRa's Avatar
yea they had it but didnt hook it up. Went off the wideband in the car.
Solid 12.9-13.0 NA and 12.4-12.5 with 50 shot
__________________
94_cobRa is offline
Old 06-30-2012, 04:33 PM   #4
I'm seeing an epidemic of cars breaking up lately. You should read tripleblackvert, Gilroyracing and dart347's threads. They are all going through it also. TripB fixed his by locking out his timing. While not the real cure it made his problem go away.
__________________
Mark Thompson PSCA Mustang Maddness 37
84 Mustang GT, Vic jr intake, quickFuel Q650 double pumper, GT40heads, TFS stage1 cam w/ 1.7RRs, NOS crosshair plate, BBK X-pipe, TKO 500, aluminum drive shaft, sub frame connectors, MSD Digital 6 Plus box, 3.73 gears
FordFreak300 is online now
Old 07-02-2012, 02:43 PM   #5
94_cobRa's Avatar
Yea I am thinking its the distributor but not sure.
I am thinking of putting a 100 shot on it, the 50 shot just doesnt do it for me. Look for around 475whp
I really thought I would make at least 400whp NA. If it wasnt low compression I probably would have been closer to what I wanted.
__________________
94_cobRa is offline
Old 07-02-2012, 04:20 PM   #6
Venom351_R's Avatar
very nice, real close to that 400 mark just on the engine alone.
__________________
1994 SVT Cobra #42 of 5009/ 95 Cobra R drivetrain
Performance- FTI TFS Custom CNC Ported 234HR High Ports /Edelbrock Victor 5.8/FTI Camshaft/Accufab 75MM TB/ PMAS 95MM Velocity Meter/Tremec 3550
Venom351_R is offline
Old 07-02-2012, 04:36 PM   #7
94_cobRa's Avatar
Thanks. Yea was reaaaally shooting for the 400 but not yet there.
Was hot as hell in the shop too, wonder if that hurt the #'s
__________________
94_cobRa is offline
Old 07-03-2012, 09:53 AM   #8
2 cam sam's Avatar
Nice numbers! Why such low compression though?
__________________
1997 Novi 2000 powered Cobra droptop
2008 Gt stock
2 cam sam is offline
Old 07-03-2012, 04:06 PM   #9
94_cobRa's Avatar
Original plans were for a turbo setup
__________________
94_cobRa is offline
Old 07-03-2012, 04:10 PM   #10
Smurfs stang's Avatar
Nice improvement!!!!
__________________
1989 Sonic Blue Mustang LX Coupe, 349 ci, TW heads, TFS Track Heat intake, 75mm Accufab TB, 80mm ProM, 30 lb inj., Jay Allen cam, TKO, 3.73, 31 spline w/ TruTrac, MAC 1-5/8" LT headers w/ h-pipe, 2-1/2 flowmaster, electric fan oh and a Moates QH
392 rwhp 424 rwtq....Mustang Dyno
Smurfs stang is offline
Old 07-03-2012, 07:50 PM   #11
Can't beat na numbers like that in a white 04 cobra. Should pick up more spun to 7000. I never sprayed my old fox but my ls1 picks up 14mph on spray. Don't be afraid man.
19935.slow is offline
Old 07-03-2012, 10:04 PM   #12
2 cam sam's Avatar
You mean in a white 94 Cobra.
__________________
2008 Gt stock
Old 07-06-2012, 01:49 PM   #13
9 and 0 are next to eachother lol. Jussst a typo.
Old 07-11-2012, 07:09 PM   #14
Nitrous SSC's Avatar
Looks good very strong runner.
__________________
Matt, 90' GT 347, 6037 heads, V1 S-trim, 11psi, B31, SV Intake, BE/Tweecer Tuned. 550rwhp 513tq
Bonneville 130 club member. (139.993) 11.48@123 in the 1/4.
04' Marauder 268rwhp/295tq.
Nitrous SSC is online now
Old 07-12-2012, 02:37 PM   #15
94_cobRa's Avatar
thanks!
thinking about converting to 3 bolt flange's and 3" exahust. Think that will pick it up?
__________________
94_cobRa is offline
Old 07-13-2012, 10:10 PM   #16
Originally Posted by 94_cobRa View Post
thanks!
Flowmaster 15930 - Flowmaster Ball Flange Kits - Overview - SummitRacing.com
__________________
93GRNLX is offline
Old 07-14-2012, 08:24 AM   #17
Venom351_R's Avatar
What is your compression at?
__________________
Old 07-14-2012, 10:37 AM   #18
Dart347GT's Avatar
thanks!
When I switched from shortys and a 2.5 exhaust to 1 3/4 LTs and 3 inch exhaust I picked up a little over 4 mph in the 1/4. My compression is also low, and Im still NA.
__________________
1992 LX hatch, midnight blue/RNH Dart 347/9.0:1/TFS TW 170/Victor Jr/Q750/FTI cam/1 3/4 LTs/3" Xpipe, 3" magnaflows/Hanlon TKO 500/4:10's/3225lbs
EFI - 12.37 @ 119.57, 91mph 1/8 w 2.11 60ft/ 358hp,366tq
CARBED - times to come
Dart347GT is offline
Old 07-21-2012, 04:23 AM   #19
Breaking down at around 6300? Is it like it's hitting a speed limiter? Has the Max PIP scalar been bumped up? I don't recall the exact name of the scalar off the top of my head...
Scaffy is offline
Old 07-21-2012, 08:27 AM   #20
rkloehn's Avatar
Trader Feedback: (18)
What did they use to tune it? Chip?
__________________
92 GT. FORDSTROKERS 363 Novi 1200i 9:1 pistons, custom freezy cam, 764rwhp 714tq Mike Post tune DYNOTUNEMP.COM FORDSTROKERS IS WHERE ITS AT!!!
rkloehn is offline
Old 07-23-2012, 12:37 PM   #21
94_cobRa's Avatar
Ok here is an update.
The compression is low because of previous plans for turbo +/- 9.4:1 (13.8cc dish)
Being tuned with Moates QH and a wideband.
Yes the breakup is very similar to a rev limiter but I am not sure about the max PIP scalar
Full 3" exhaust has been installed and waiting to go back to the dyno for an update. I went with a 3" universal summit racing X pipe and 3" Dynomax Ultra Flo Welded mufflers with turdowns. I didnt have the resources to do bolt on collector flanges so I am using band clamps on the header collector to x-pipe until I can put some bolt on connections.
__________________
94_cobRa is offline
Old 07-26-2012, 11:30 PM   #22
1svtfan's Avatar
MNPIP8- 6504 by default
1svtfan is offline
Old 07-27-2012, 02:13 PM   #23
Not on 94-95 car , 7503 by default
__________________
93GRNLX is offline
Old 07-27-2012, 02:29 PM   #24
94_cobRa's Avatar
Could this be the problem Willie?
__________________
94_cobRa is offline
Old 07-28-2012, 12:38 AM   #25
cw50's Avatar
Yep, T4M0 is 7503 for 8cyl. PIP.
Funny thing is add me to the list of breaking up issues. Dynoed last year, no issues, changed plug wires/cap/rotor, heads (6037s to AFR185s), ported intake and went back to the dyno this year and it was breaking up like crazy and made less whp than my old setup ... All other things being equal and I was breaking up above 4200. Tuner concluded I was dropping a cylinder.
I did notice my new wires (Taylor ThndrVt 8.2's) had holders loose on #3,6,7. Pull on the wire and it slipped right out of the plug crimp (just fixed this past weekend). Then again plug #8 look pretty clean (no spark?). I'm going to try a new dizzy since current one is a remanf cardone unit.
Since A/F looks good, datalog "spark source" and load--it will tell you what spark table position it's using and you can probably narrow down where spark is messing up (if it's a tune issue).
__________________
'95GT: XB1a-blown@14psi B50-CP & Eagle forged-331ci, AFR 185s, custom cam, ported RPM2, new fuel, exhaust, MM stuff.
'02 WRX
'04 SVTF
'05 BLM Mustang , #645765, 16 Hands, 1HP
cw50 is offline
Old 07-28-2012, 07:57 AM   #26
just leave the band clamps. less prone to leakage
slow87GT is offline
Old 07-30-2012, 08:09 PM   #27
94_cobRa's Avatar
Update-
No dyno sheet, but did make it back to the track. Unfortunately I think its safe to say the 3" exhaust did absolutely nothing. Previous times with 2.5" exhaust were all consistant 11.8@115. New times the same. 11.8@115 with similar 60' times (always spinning to a 1.6x).
I was not the happiest camper. The last pass I decided to power shift from 1st to 2nd and 3rd to 4th and gained 2mph. First and only time I have ever powershifted the car. Gained 2mph but nothing else changed.
__________________
94_cobRa is offline
Old 07-30-2012, 08:20 PM   #28
white-stang's Avatar
The ET`s look better, I would think the mph is still low for 400 hp
__________________
80 mustang, 331, ported E7`s, 780 vac sec, rpm airgap, mac 1 5/8 lt`s, C4 w/3200 stall, 255x60x15 MT dr`s, 3.73`s, Cam 228/236 .544 lift w/1.7`s
1.56 60ft. 1/4mi ET 11.46 @ 117.12 mph
1/8mi 7.26 @ 93.64
3020 lbs with driver.
white-stang is offline
Old 07-30-2012, 08:45 PM   #29
94_cobRa's Avatar
the Et's didnt change by much at all if any.
__________________
94_cobRa is offline
Old 07-31-2012, 07:06 PM   #30
Dart347GT's Avatar
Sorry to see that the new exhaust didnt help as much as you wanted. I couldnt believe how much it helped me, but my FTI cam was made for the parts I have now, not the small stuff I was running so maybe thats why I picked up what I did.
__________________
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
