Trickflow 170's overkill on close to stock 302? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 05-14-2012, 04:06 PM Thread Starter
My original engine build up plans, of which I have all the parts for, is GT40P heads, Explorer intake and injectors, stock cam, 65mm TB, and shorty headers. Car is an 86 GT with 3.55 gears, modified exhaust.
I am considereing the Trickflow twisted wedge 170 heads in large part because of the ease, bolt on and go, versus checking PTV and possibly having to get the valve reliefs done by someone. And I still have to get the GT40P's checked and could be looking at some machining work costs. I really the idea of taking off weight from up higher on the front end of the car. I was going to stay with the stock GT cam, so no plans to switch from speed density. Would I loose power in the lower rpm's versus the smaller valves and ports on the GT40P heads? Would I really gain much considering the mildness of the rest of the engine? Thanks greatly for any feedback.
ledfut is offline
post #2 of 11 Old 05-14-2012, 04:51 PM
Old timer
Ed Curtis's Avatar
TW on a stock short block thread
Read this and see what can happen if you plan things properly.
"Haters gonna hate 'cause they just can't replicate."
Ed Curtis is offline
post #3 of 11 Old 05-14-2012, 05:08 PM
pillowofwinds's Avatar
Definitely not overkill. I have those heads and a can from ed on a stock bottom end and I've run in the 11s at 116+. I'll have dyno numbers this weekend. I know there's some others here that will chime in and agree
Sent from my Galaxy Nexus using Tapatalk 2
90 lx coupe - too big of heads and too big a cam, 4.10s
10.69 @ 127.8 NA stock bottom end
pillowofwinds is offline
post #4 of 11 Old 05-14-2012, 05:12 PM
j.youngberg's Avatar
A lot of good info in that thread. Thanks, Ed.
Sent from my LG G2x
'91 LX 5.0 Vert: Explorer Intake, 3.73s, T5 swap, VRS X-pipe
j.youngberg is offline
post #5 of 11 Old 05-14-2012, 07:02 PM
Trader Feedback: (27)
Go with the trickflow you can sell the gt40 to help offset some of the cost.
100percentstock88 is offline
post #6 of 11 Old 05-14-2012, 08:34 PM
tripleblackvert's Avatar
Trader Feedback: (74)
im honored! lol
1987 Notch - N/A stock 302, TFS heads, Holley Systemax, FTI cam, Astro A5
Best so far: 10.92 @ 123mph with a 1.49 60ft
tripleblackvert is offline
post #7 of 11 Old 05-22-2012, 09:57 AM
Gregg@TrickFlow's Avatar
As you can see in the thread listed above the 170cc heads are not overkill. That head will work great on your combination and still give you room to grow in the future. If you have any questions feel free to call me at 330-630-1555.
Thanks, Gregg
[SIGPIC][/SIGPIC]
Gregg@TrickFlow is offline
post #8 of 11 Old 05-22-2012, 10:25 AM
USAF retired
superirish's Avatar
Trader Feedback: (39)
Location: Foht Walt'n Beach Floriduh aka The Redneck Riviera
Not at all, I run a set of ported 170's on a mostly stock shortblock, in a 4 door sedan with no issues. Don't believe the internet myths.
1985 LTD LX, small truck motor, painted axle tubes, various mustang stuff.
1990 LX stock porno block, '86 flattops, cobra flywheel, ported GT40s, Vic Jr 4-hole throttle body, DB1 speed density processor, B-cam
, 1.7s, 4.30s, stock T5 living on borrowed time.
superirish is offline
post #9 of 11 Old 05-23-2012, 07:56 PM
87Fox5.0's Avatar
Have them on a stock 289 block.
'87 Fox C-Prepared Autocross Machine
Trophied at 2015 and 2016 SCCA Nationals
87Fox5.0 is offline
post #10 of 11 Old 05-23-2012, 09:47 PM
mhinchley's Avatar
Trader Feedback: (44)
Those heads are great and leave lots of room for growth. Last year I pulled 637/573 with those heads untouched. Lots of bang for the buck.
03 Whippled E85 Cobra Vert & 00 ZX12R
4r70w swap in progress 9-1-14
mhinchley is offline
post #11 of 11 Old 05-24-2012, 09:28 AM Thread Starter
Thanks for all the replys and info. I believe I'll be fine with the 170's. And should be a no hassle install on the '86. There is a guy at work who will buy my GT40P's for $250 and I ended up NOT buying a set of NOS back window louvers for $500, so I'm already close!
ledfut is offline
