Dyno results- TFS170, Holley SM2, FTI cam - Page 2 - Ford Mustang Forums : Corral.net Mustang Forum
Old 04-02-2012, 01:33 PM   #36
tripleblackvert's Avatar
Trader Feedback: (66)
I should also mention the low rpm drivability on this is outstanding...45mph, 1600rpm in 5th gear, no bucking at all...awesome job Ed
__________________
1987 Notch - N/A stock 302, TFS heads, Holley Systemax, FTI cam, Astro A5
Best so far: 10.92 @ 123mph with a 1.49 60ft
tripleblackvert is offline
Old 04-02-2012, 01:54 PM   #37
Angry_Man's Avatar
Does the cam card refer to it as a "street beast"?
__________________
"Σίσυφος had it easy"
Angry_Man is offline
Old 04-02-2012, 02:21 PM   #38
Nope. SBF Rebel series
I had to install it at 2* retarded on the timing set. The .050" opening events are still about 1/2 a degree advanced...close as I could get it.
__________________
Old 04-02-2012, 02:29 PM   #39
Hell add 700lbs and its still an 11.90-12.0 setup @ 3450 race weight
__________________
Old 04-02-2012, 02:31 PM   #40
Angry_Man's Avatar
Very impressive track times. What sort of vacuum does it pull at idle?
__________________
Old 04-02-2012, 02:34 PM   #41
I don't know lol
Only vac line on my car is for the fp regulator....which is stock..
__________________
Old 04-02-2012, 03:11 PM   #42
94_cobRa's Avatar
Trader Feedback: (71)
thats right there with me 11.8 @3350#. I need to get a better 60. 4.11' chunk w/ locker should be in tomorrow too!
What is your total timing?
__________________
stock block 94 Cobra pump gas 9.2:1 347, RHS 215 , Victor EFI, FTI NA cam, 80mm Fox TB, 4" Intake, SCT 2400 MAF, 42lb injectors, 1 3/4 Lt's/3" exh, stock T5, & Ford 9" 4.11 - 429whp/400tq
10.7@127 - 1.49 60ft.
94_cobRa is offline
Old 04-02-2012, 04:00 PM   #43
I don't know either..dizzy is at 10 base..i told the tuner "aggressive as possible" lol...
I haven't checked anything with the light yet
__________________
Old 04-03-2012, 11:35 PM   #44
boosted92's Avatar
Nice Numbers, Thing is Haulin!
__________________
NA Stock Bottom End TFS Heads AFM N-51 Systemax...331whp 336wtq SAE 11.89 @114.5mph. Sold
boosted92 is offline
Old 04-04-2012, 03:06 AM   #45
thanks man...you gets yours to the track yet?
__________________
Old 04-04-2012, 10:27 AM   #46
badbrad's Avatar
Trader Feedback: (30)
coukld you share any cam specs? particularly the duration at .050? just trying to see what up, make me think theirs hope for mine once i get it tuned. mine is about 500lbs heaviers too!! (my dd)
__________________
89 lx vert stock block/bore, tw 170's, xe266 comp cam
performer intake, 70mm tb, 76mm meter. 3:55's
constant work-in-progress
badbrad is offline
Old 04-04-2012, 11:17 AM   #47
__________________
Old 04-04-2012, 12:31 PM   #48
408foureye is offline
Old 04-04-2012, 12:41 PM   #49
it seems to be working....
i have Ed's LSx valve spring kit on them
__________________
Old 04-04-2012, 01:01 PM   #50
badbrad's Avatar
thanks, that's awesome
__________________
badbrad is offline
Old 04-06-2012, 02:48 AM   #51
boosted92's Avatar
First time out went 12.004 @112 changed the meter and intake and need to run it again. My 3400 race weight kinda kills my et.
__________________
Old 04-06-2012, 03:03 AM   #52
Yeah sure does! Lol
__________________
Old 04-06-2012, 01:27 PM   #53
Project Reef Blue's Avatar
Good job trippleblack vert! How the heck did you get that thing so light?
__________________
306, 9:1, OOTB TFS TW's, Systemax II, F303, 1 5/8 Longtubes, 3" Magnaflow Cats, Xpipe, Spintech Sportsman, 24lb inj, 75mm TB, 85mm MAF, Powerpipe, Tweecer, t5, 4.10s, UPR kmember, Strange adj, airbag, 26x10, etc.
332rwhp 332rwtq 11.78 @ 115.83 3100lbs
http://www.youtube.com/user/ProjectReefBlue
Project Reef Blue is offline
Old 04-07-2012, 03:28 AM   #54
Sacrifice my friend, haha..
Went to the track again last nite, blew 3rd gear apart...that didn't take long lol
__________________
Old 04-07-2012, 07:27 AM   #55
Stock t5? How were you shifting?
__________________
1.72 7.54 94.83 bolt on stock block with some sneeze, suspension, mickeys and a tired ol' T5
carb'd 306 under construction
93twfox is offline
Old 04-07-2012, 07:52 AM   #56
GilroyRacing's Avatar
Trader Feedback: (83)
Damnnnnn man
__________________
91 Fox
R.I.P. 347: 1.43 60' 6.78@101.30 1/8th 10.64@127.84 1/4
302 1.59 60' 7.63@88.19 12.06@110.58
GilroyRacing is online now
Old 04-07-2012, 09:02 AM   #57
i powershift that ho...i dont have time to be lifting my foot off the gas, wtf?!?! lol
stock-ish t5..rebuilt it all late last season(august maybe?) new 3rd gear, all new synchro's bearings, etc, steel bearing retainer and billet cluster support..tore it back apart this winter and added a new 2nd gear and 1-2 slider, cuz i ran out of cash during the first rebuild, otherwise those would have been replaced them...
so i made one pass last nite, with 2 full street tires/10 holes in the trunk/rear seat, and some other #### for added weight, short shifted at 5800 and left at 3900 on the 2 step, trying to sandbag cuz i dont have a rollbar yet..still went 11.45 @ 117mph
2nd pass, same setup, hit 3rd, then 3rd hit me back lol
i have over 400 powershifted passes on this trans in the past 3 years with the last h/c/i combo..this setup lasted about 8 passes hahaha
__________________
Old 04-07-2012, 09:32 AM   #58
lol I figured you were power shifting. I was just curious, I've got a stock t5 (minus steel bearing retainer) behind my motor. Yours took a beating before giving out though, tough little t5.
__________________
93twfox is offline
Old 04-07-2012, 09:40 AM   #59
the light weight had to help im sure...i even switched to an aluminum flywheel with the new setup in hopes of hitting it a little softer..guess that didnt help
__________________
Old 04-07-2012, 11:04 AM   #60
What are your plans now?
__________________
91 Fox
Old 04-07-2012, 11:05 AM   #61
JOHNNY HORSEPOWER's Avatar
Very nice times on the track for the dyno numbers. I wish my turd was that light. I need to find out how much my car weighs and put it on a diet somehow. I would really be flying if I can take a lot of weight out of my car and be as light as yours.
JOHNNY HORSEPOWER is offline
Old 04-07-2012, 11:12 AM   #62
short term, throw a spare trans in and shift like a pu$$y
long term, A5 gear set
__________________
Old 04-08-2012, 08:57 PM   #63
2 cam sam's Avatar
Nice combo and runs. Its nice to see one running so strong with minor mods. Do you no what the da was when you ran ?
__________________
1997 Novi 2000 powered Cobra droptop
2008 Gt stock
2 cam sam is offline
Old 04-08-2012, 09:51 PM   #64
justintx75's Avatar
could you give us some more details on the set up such as were the heads ported?
__________________
1990 GT 5.0 5 speed i used a low mileage explorer motor ported the gt40 heads w/ a tfs street and a E-cam.
the car runs much better than stock now, looking to upgrade to TW alloy soon
justintx75 is offline
Old 04-08-2012, 10:04 PM   #65
DA on those passes was about 1250ft
heads were milled .005"
i went thru the heads with some 80grit cartridge rolls and smoothed out the rough casting marks, and blended the bowls a bit..didnt remove much material at all..was too afraid to ruin them
3rd gear doesnt work anymore
__________________
Old 04-08-2012, 10:31 PM   #66
Cobra427's Avatar
AAAAOOOOUUUCCCCHHHHHHH!!
__________________
93 SSP 3220 lbs,W/C T-5,3.90's,ported gt40 irons,stock valves,cut/ported Cobra upper,ported lower.30# inj.SVT MAF,Bcam/1.7'sN/A-12.43@109.65 1/8-7.931@86.85 DA 1083,1.74 60',old Nitto Dr's Catted UPR X, stock airbox and full emissions equip still on the car.passes Cali emissions
Cobra427 is offline
Old 04-08-2012, 10:33 PM   #67
Lol, I understand that. The A5 is a badass trans I've been wanting one for a while now..... But after talking to mark (ford freak) and Ricky (331TW) I am saving my pennies for a face plated TKO!!
__________________
91 Fox
Old 04-09-2012, 01:00 AM   #68
S-Trimmed302's Avatar
Trader Feedback: (96)
Very impressing Times that combo is Flying for such a simple combo.Ed comes thru again!
__________________
Sent by me...
Originally posted by Fomoco347
One time i drove my car with 3 rims cuz i couldnt afford the 4th rim,
S-Trimmed302 is offline
Old 04-09-2012, 07:04 AM   #69
I wasn't expecting much...i WAS running a Bcam after all...Bcam would never have done that to my poor T5!
__________________
Old 04-09-2012, 11:09 AM   #70
not that it matters because the numbers are awesome, but is the 6k rpm limit a function olf the stock bottom end or the cam or...everything?
89koup is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
