car wont start after MAF conversion - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 23 Old 10-26-2011, 10:09 AM Thread Starter
crzy88lx's Avatar
its in 88 5.0L.
i have an 89 wiring harness with a 93 cobra ECU, Mass Air Meter, and injectors.
it has fuel and spark and the timing appears to be good as well.
what is the problem? it wont run at all.
5 lug conversion, 4.10 gears, aod to t-5 2.95 conversion
cold-air intake, headers, off road x-pipe and flowmasters
17" '95 cobra wheels with toyo tires
tubular k-member and a-arms w/ coilover front suspension, lakewood drag shocks.
crzy88lx is offline
post #2 of 23 Old 10-26-2011, 10:13 AM
kevinmsvt's Avatar
Trader Feedback: (39)
did the car you got the parts from run?
twisted wedge,harland sharp rockers,comp xe282hr
cam,vic jr. 750 proform dp.....cold a/c daily driver now a 347!!! new times to come!!
kevinmsvt is offline
post #3 of 23 Old 10-26-2011, 10:17 AM Thread Starter
crzy88lx's Avatar
yes it did.
crzy88lx is offline
post #4 of 23 Old 10-26-2011, 10:18 AM
indy2000's Avatar
I don't believe a cobra came in auto.
Do you still have the auto o2 harness on the car?
I see you listed an auto to t-5 conversion.
indy2000 is offline
post #5 of 23 Old 10-26-2011, 10:29 AM Thread Starter
crzy88lx's Avatar
i do. why would that matter though?
crzy88lx is offline
post #6 of 23 Old 10-26-2011, 10:42 AM
kevinmsvt's Avatar
just for giggles unplug the maf and see if it will start
post #7 of 23 Old 10-26-2011, 08:59 PM
indy2000's Avatar
I believe the auto harness (o2) used with a 5spd ECM will fry the ecm.
There is a long well documented thread about this subject, use the search.
indy2000 is offline
post #8 of 23 Old 10-27-2011, 08:36 AM Thread Starter
crzy88lx's Avatar
I used the auto O2 harness with the stock 88 ECM before i converted to mass air and had no problems. are you saying that since that ECM was also for an Auto, that that is why this new ECM isnt working?
if the ECM wasnt working, then why would i still have fuel pressure? wouldnt it not run the fuel pump too?
crzy88lx is offline
post #9 of 23 Old 10-27-2011, 09:44 AM
indy2000's Avatar
Oxygen sensor Harnesses - Manual/Auto differences and year differences
Its in these forums already.
indy2000 is offline
post #10 of 23 Old 10-28-2011, 11:29 AM Thread Starter
crzy88lx's Avatar
ive done some research and the o2 harness is fine for my year. if i had a wiring harness from a 91 or older is when it might fry the ECU. because they had a different o2 harness in those years.
so the o2 harness sounds like that is not the problem.
anthing else it might be?
crzy88lx is offline
post #11 of 23 Old 10-28-2011, 09:28 PM
indy2000's Avatar
auto harness and 5speed ECM do NOT work, regardless of year.
so what do you mean yours is fine?
indy2000 is offline
post #12 of 23 Old 11-03-2011, 10:19 PM
so it does crank but just doesn't fire up?
88 LX 331 stroker
bart works sla/ mm rear co with phb
MYOWNR is offline
post #13 of 23 Old 11-04-2011, 06:40 AM
tripleblackvert's Avatar
Trader Feedback: (74)
Remove the computer, the hook up a volt meter between PIN 46 on the computer connector(on the car) and a good ground...clutch down, crank the engine with no computer and check for any voltage while cranking on pin 46...if you see any voltage, the o2 harness is set up wrong and your computer is fried...but fixable...
1987 Notch - N/A stock 302, TFS heads, Holley Systemax, FTI cam, Astro A5
Best so far: 10.92 @ 123mph with a 1.49 60ft
tripleblackvert is offline
post #14 of 23 Old 11-05-2011, 12:26 AM
Bobert's Avatar
Trader Feedback: (18)
The tricks we learn from other members is just amazing. Try it out and luk
Bobert is offline
post #15 of 23 Old 11-05-2011, 01:24 AM
I had the same problem when I converted my 87 to mass air. I had spark fuel and timing was good but it wouldn't turn on. I had forgotten to change the MAP sensor on the firewall to MAF sensor. Did you change yours out? If not give that a try
AR_Stang is offline
post #16 of 23 Old 11-05-2011, 04:08 AM
MAP to BAP actually, not maf
post #17 of 23 Old 11-05-2011, 01:22 PM
Yes, that
AR_Stang is offline
post #18 of 23 Old 11-07-2011, 02:51 PM Thread Starter
crzy88lx's Avatar
i guess i dont know if i did that or not. i think i just had the MAP sensor on there still. what is a BAP and how do i obtain one? what does it look like?
crzy88lx is offline
post #19 of 23 Old 11-07-2011, 03:03 PM
Papa Cosmos's Avatar
All you need to do is disconnect the vacuum line to the one you have now. That is all I did to mine and it works fine.
Sent from my SGH-T589 using Tapatalk
Papa Cosmos is offline
post #20 of 23 Old 11-08-2011, 08:36 AM Thread Starter
crzy88lx's Avatar
i tried that last night. does not start still. here is a picture of the sensor i have. the numbers on here do not match the sensor i found on latemodel though. do i have the right one?
this one is mine.
here is the one from late model
1989-93 Mustang 5.0L Barometric Air Pressure Sensor (Bap Sensor) at LRS - Same Day Shipping!
maybe thats my problem?
im still not ruling out that i might have the wrong o2 harness and i might have fried the ECM.
crzy88lx is offline
post #21 of 23 Old 11-08-2011, 11:46 AM
Blackfive0's Avatar
Trader Feedback: (60)
The one you have is fine just unplug the VAC line.
Blackfive0 is online now
post #22 of 23 Old 11-08-2011, 12:40 PM Thread Starter
crzy88lx's Avatar
i did that. it didnt work.
crzy88lx is offline
post #23 of 23 Old 11-08-2011, 01:24 PM
when you unplug the vac line, you also have to cap it off(the line, not the sensor) or else you'll have a vacuum leak.
go back and complete and/or re-check each of these steps, theres more to it than just changing the computer
Mustang Mass Air Conversion «
