what height do you set your gt40 valve springs to - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 09-11-2011, 04:02 PM Thread Starter
Lightbulb what height do you set your gt40 valve springs to
So I have gt40 heads and new valve spring kit from Alex Parts that I want to install. I have been reading a lot about install height, coil bind, and all sort.
I have stock cam with 1.72 rockers so my lift will be around .477
The springs install height @ 1.78 is 120lbs
----------------coil bind @ 1.100
----------------max lift @ .600
So if I install it at 1.78 with my .477 lift I will have .203 before coil bind...
I have the hardened shim kit so am I going to want to bring the install height down to 1.7-1.71 to be closer to .130 before coil bind
or
bring the intall height down more to be closer to .60 range... I have read multiple posts and threads and each one says something different so I would like to get an opinion on here.
I plan on going turbo with these heads in the future so I want to get this right the first time.
dirty2003 is offline
post #2 of 9 Old 09-12-2011, 08:49 AM
worry more about open and closed pressures, when you get the proper closed pressure on the seat then what ever intalled height it took to get that, so be it...and it may fall within what spec says, but you must check that and have proper stuff to do such, after that coil bind can be checked ,ect ect , knowing the cam to be used is important as well.
85gt66 is offline
post #3 of 9 Old 09-12-2011, 10:34 AM
what is spring rate.
2007 BMW 335i
Goody_Seven is offline
post #4 of 9 Old 09-13-2011, 02:25 PM Thread Starter
Its a 120lbs at 1.78" for the seat pressure.
post #5 of 9 Old 09-13-2011, 02:40 PM
Spring rate?
bender4601 is offline
post #6 of 9 Old 09-13-2011, 11:21 PM Thread Starter
sorry about that here are all the specs i have for the springs.
Spring Specifications:
•1.460" Outside Diameter
•.980" Inside Diameter
•120 Lbs @ 1.780" Valve Closed Installed Height
•280 Lbs @ .500" Lift
•310 Lbs @ .600" Lift
•No spring seat machining required
post #7 of 9 Old 09-14-2011, 10:39 AM
Here is what I would do.. Some one please check my math....
coil bind-----1.100
Lift----------0.477
clearance----0.123
Installed height 1.700
At 1.700 145lbs (seat)
At 1.223 297lbs (at lift)
320lb rate.
post #8 of 9 Old 09-16-2011, 12:56 AM Thread Starter
Bump.... that sounds about right. Anybody else have some input
post #9 of 9 Old 09-16-2011, 06:10 AM
tripleblackvert's Avatar
Trader Feedback: (74)
You dead set on those springs? The open rates on those Alex springs looks pretty weak, considering stock springs are at 230lbs open..i think the stock rate is like 315lbs/in if my math is correct...i wouldnt run those...i would run from those...
ive been using:
Crane 44308-1
adv. specs:
118Lbs @ 1.950
Coil bind- 1.320"
Open- 375lbs @ 1.380"
457 lb/in rate
Install @ 1.880" will put you .083" from coil bind
~150 on the seat and ~370 at lift
1987 Notch - N/A stock 302, TFS heads, Holley Systemax, FTI cam, Astro A5
Best so far: 10.92 @ 123mph with a 1.49 60ft
tripleblackvert is offline
