Rocker arms wont stay tight - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 08-06-2011, 10:39 AM Thread Starter
hey guys I need some help my rocker arms wont stay tight its a soild roller with twisted wedge R heads . Ive been been tighting them down to cam card specs I measured push rod length Im using comp cams rockers the poly locks seem to back of .
brits 86 gt is offline
post #2 of 14 Old 08-08-2011, 10:50 AM
tmoss's Avatar
Trader Feedback: (47)
do you tightern the allen and then put a socket on the nut and give it another 1/8 turn or so?
Tom Moss
tmoss is offline
post #3 of 14 Old 08-08-2011, 04:09 PM
67mike's Avatar
Wink
I had that issue as well....untill I got them dialed in....tighten the allen lock down THEN I get the allen key and box wrench lined up one on top of ech other and give (BOTH at the same time) another 1/8th turn or so...they will "squeek"....haven't had an issue since.
1967 GT Coupe, 4 speed toploader, 393W, Custom Cam, Canfield Heads, Vic Jr Intake, Crane Ignition, Holley Ultra Avenger Carb, etc........
2003 GT Convertible, K&N cold air system, Magnaflow cat back, auto...MINT...Loving it!
67mike is offline
post #4 of 14 Old 08-08-2011, 04:09 PM
I guarantee hes not.
630-462-3978 Shop Direct
877-723-5487 Shop Toll-Free
TONS of Build Photos Ck at
Make sure to sign up for
strokeme is online now
post #5 of 14 Old 08-15-2011, 08:31 PM Thread Starter
K thanks guys . I will try a socket this time what if this dont work should I go with a shaft rocker arm?
post #6 of 14 Old 08-16-2011, 10:36 PM
blue93hatch's Avatar
Trader Feedback: (26)
not socket box end wrench, unless you have a rachet with a hole through it
blue93hatch is offline
post #7 of 14 Old 08-17-2011, 11:52 AM
tmoss's Avatar
I have a set of ratchets and sockets that do - for use on long studs primarily. MAC makes them and I bet so do others.
Tom Moss
tmoss is offline
post #8 of 14 Old 08-17-2011, 12:48 PM
Splitting hairs -__-
post #9 of 14 Old 08-17-2011, 07:08 PM
kbernal1016's Avatar
Trader Feedback: (27)
Couldn't you also use oil resistant thread locker?
89 Mustang LX 5.0 Coupe, C4, stripped, etc.
95 Mustang GT 5.0, IRS, 3550, etc.
03 F150 FX4 Supercrew 5.4, Lariat, lifted, etc.
06 Focus ZX4 2.0, MPG!
kbernal1016 is offline
post #10 of 14 Old 08-17-2011, 07:17 PM
No thread locker, its really quite simple. You are simply not listening. Set needed lash with the 5/8ths poly then simply run the set screw in till it stops. Now go another eighth to a quarter turn with the polylock AND setscrew together. Never come loose again.
Sent from m y Desire HD using Tapatalk
post #11 of 14 Old 08-17-2011, 07:27 PM
botlrokit93's Avatar
youre running a solid roller, therefore you are running a specific lash value.... recheck your lash after locking the allen screw and giving the poly another "crank till it squeaks".... I found that I needed to set my lash bout 3-5 thou loose, then give the poly that extra crank to lock it. recheck lash to make sure its in spec after "final lockdown" just my $.02
AARON
_______
botlrokit93 is offline
post #12 of 14 Old 08-17-2011, 07:43 PM
tmoss's Avatar
absolutely
Tom Moss
tmoss is offline
post #13 of 14 Old 08-17-2011, 09:48 PM
What about with pedestal type rockers?
I throwing some thoughts out...
post #14 of 14 Old 08-17-2011, 10:00 PM
then its just a bolt not a nut/lock on a stud so theres nothing to set. Tighten down and go
