Fox body carb'd guys, which cable and bracket you running? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 33 Old 06-22-2011, 10:10 PM Thread Starter
Wicked03GT's Avatar
Trader Feedback: (49)
Just curious as to which throttle cable and carb bracket I should be using for my 88 LX?
The one I have on it right now works fine, but its not adjustable in any way. and it looks as if the bracket itself is a homemade deal. I wouldnt be too concerned about this in any way, its a very good way its set-up, but I absolutly HATE how stiff my gas pedal is. It actually makes the car hard to drive cause you either push hard on the pedal trying to get it to rev up and pull out with the cam, or you dont push hard enough and nearly stall the car.
Wicked03GT is offline
post #2 of 33 Old 06-22-2011, 10:26 PM
Lokar SRK-4001 - Lokar Throttle Cable Brackets - Overview - SummitRacing.com
and
Lokar TC-1000HT - Lokar Throttle Cables - Overview - SummitRacing.com
2013 Grabber Blue GT Premium A6 Procharged
9.93@137 10psi
Bubba408str is offline
post #3 of 33 Old 06-22-2011, 10:54 PM Thread Starter
Wicked03GT's Avatar
Sweet and cheap huh? How adjustable is that set-up, and will I be able to adjust it to get the pedal feel I like?
Also, is there a difference in the 4 cyc pedals and the 8cyc? I dont want to run into any crazy problems...
post #4 of 33 Old 06-23-2011, 01:10 AM
89fiveohmustang's Avatar
I've got the stock aod throttle cable.... with csr bracket sell them on summit for about 40 bucks. i have a lokar cable to match it just haven't install yet. .. but the csr bracket is anodized, cheap, and adjustable can't beat it !
03 svt cobra redfire
89 lx 347
89fiveohmustang is offline
post #5 of 33 Old 06-23-2011, 09:45 AM
Fast82LX's Avatar
The one I use is the AED Throttle Cable Bracket, the one with the return Spring.
It is Very adjustable and use it with a stock Carb throttle cable from and 82-86 Mustang. NHRA Legal too.
~Republic of Texas~
~Silver Foxbody w/ Fordstrokers 363~
Fast82LX is offline
post #6 of 33 Old 06-23-2011, 10:47 AM Thread Starter
Wicked03GT's Avatar
Might go with that AED with the return spring, since I could use my already in place cable and still keep the officals happy when I make it to the track.
post #7 of 33 Old 06-23-2011, 11:00 AM
Shifter's Avatar
Trader Feedback: (191)
THIS!^^^
Shifter is offline
post #8 of 33 Old 06-23-2011, 12:24 PM
AED here also...you need a double return spring to be legal at the track
89 coupe - FordStrokers 347, TFS FAC 190, C.I. custom HR, Victor Jr. intake, Pro-Systems 780, MSD, Kooks 1 3/4 - 1 7/8, Astro A5, 4.10's, AJE/TeamZ/Strange susp.
tumm37 is offline
post #9 of 33 Old 06-23-2011, 01:52 PM Thread Starter
Wicked03GT's Avatar
The only problem I see, is it does not accept a transmission kickdown...So in the near future when I swap from T5 to a auto I will need to run a manual valve body no matter what.
post #10 of 33 Old 06-23-2011, 02:38 PM
HIVOLTJ's Avatar
I used a stock replacement for an '85 stick car. I couldn't find a damn stock bracket anywhere, so I made one.....
'90 LX hatch 5.0/5spd = SOLD
'89 LX COUPE 5.0/5spd = SOLD
'94 Lightning #2978 = SOLD
'77 F-150 RCLB 2wd 408 cleveland in the works
HIVOLTJ is offline
post #11 of 33 Old 06-23-2011, 04:26 PM
460capri's Avatar
Trader Feedback: (48)
I use an AED bracket and a lokar cable easy to adjust and has a very smooth action I think the lokar cables are less than 30.00 . A pic of my setup and I had mine powdercoated to match the valve covers .
85 Capri 310 , 10.1cr , solid roller cam 608"/614"x 242*/248* AFR 205 heads , 1 3/4" headers , super victor intake , holley 750DP , MSd ignition system and NOS 150 shot .
460capri is online now
post #12 of 33 Old 06-23-2011, 06:53 PM Thread Starter
Wicked03GT's Avatar
Man! That looks damn good!!!
post #13 of 33 Old 06-25-2011, 05:06 PM
Trader Feedback: (26)
You can use a stock bracket of a 79-85 mustang. It already has 1 spring on the cable, then you just need a second spring to be NHRA legal. That AED one does look nice but I bet the pedal is kinda stiff using 3 springs. 2 on the bracket and 1 on the stock cable.
86 mustangs had SEFI it was the first year. The previous years had carbs and throttle body injection.
Mark Thompson PSCA Mustang Maddness 37
84 Mustang GT, 408 super Vic intake, high port heads, pro system 1000cfm carb, inductions solutions sledge hammer nitrous system, glide. Full TeamZ suspension.
FordFreak300 is offline
post #14 of 33 Old 06-25-2011, 11:14 PM Thread Starter
Wicked03GT's Avatar
Im going to run a aftermarket cable to eliminate the factory spring/cable deal...I hate the design anyways.
post #15 of 33 Old 06-27-2011, 03:21 AM
AED bracket and Lokar cable. What I've used for years and the Lokar cable is fully adjustable. Can't go wrong.
Tooooooo many to list.
93tripleWhiteLx is offline
post #16 of 33 Old 07-29-2011, 01:35 AM
firefox34's Avatar
Question lokar cable help?
i took you guys advice i just got the lokar cable from jegs today. im trying to figure out the best way to hook the clevis end to throttle pedal since my stock one was a ball type. any help would be great
firefox34 is offline
post #17 of 33 Old 07-29-2011, 01:44 AM
86mustang408w's Avatar
Trader Feedback: (39)
I used an AED bracket, and a 85 Auto Throttle cable, it's the only one that will fit a Holley.
89 LX: 308, AFR 165 Ren., FTI cam W/LSX style springs, TFS Box-R w/Accufab 75mm, TKO 600/Spec Stge 3, Quicktime bell, 31 spl. Moser 5 lug 8.8 w/9" ends, AFM PP, Team Z Sus., Fluidyne rad, 2.5" Harwood , etc..
86 GT Hatch: CHP- 408w, AFR 205's, TKO 600, FAST XFI, sold 8/2013
06 CBR 1000RR
86mustang408w is online now
post #18 of 33 Old 07-29-2011, 11:19 AM
460capri's Avatar
Well your wrong just look at my pic that is not a stock throttle cable .
OP sorry for the long post I will tell you everything I did you may or may not know this so take no offense to my words .
You have to take the pedal off ( easiest way ) close the slit that is at the top with a hammer or vise reinstall the pedal and slip the washer over the cable then run the cable and washer into what is now a hole and run it into the part that attaches to the firewall ( I had to use a washer there also as the hole was to big for the lokar part ) and out the other end ( nice to have a buddy to help you out ) shorten the braided cable sleeve and slip the cable into the braided sleeve pull the cable all the way though and into the part you installed on the AED bracket then take it to the carbs throttle bracket where the ball is and cut there make sure the cable is all the way though and there is no slack in the cable .
Make sure all the lokar adjustment parts are at the shortest length ( look at my pic if you cant see enough let me know and I will send you a link to photobucket so you can get a real big pic ) . Now install the cable into the part that attaches to the carb you will have slack in the cable now so use the adjuster on the AED to take out the slack ( you want some slack not much maybe a 1/4 in slack ) you want to make sure the carb closes all the way when you take your foot off the pedal ( here the buddy helps again ) have him or her get in the car and push the pedal all the way down and look into the carb and make sure the blades are all the way open if not take more slack out of the cable if you cant you have to start over and shorten the cable some more then start making the adjustment again . Dont forget to attach the Dual return springs . Just remember you can always cut more of the cable to make it fit just right if you cut it to short you will have to buy a replacement cable .
You will be very happy with the end result and the throttle will work very smooth Hope this helps you out if you need to ask a question feel free to PM me and good luck .
post #19 of 33 Old 07-30-2011, 11:57 AM
The auto stock one is the only one that will fit, the manual one won't, and 86 and up will not.
06 CBR 1000RR
post #20 of 33 Old 07-30-2011, 01:26 PM Thread Starter
Wicked03GT's Avatar
I just put the Lokar cable and AED bracket on my car...Fits just fine
post #21 of 33 Old 07-30-2011, 01:37 PM
460capri's Avatar
You need to read his 1st post he does not want that stiff of a pedal and thats what you get with a stock cable even if you put it on an AED bracket so you just dont get it and that is sad here are pics of my lokar cable and the cable come with the parts need to put on a holley carb see pic thats a holley carb and the 2nd pic is a close up of the part that attaches to the holley carb .
post #22 of 33 Old 07-30-2011, 04:47 PM
Sorry for posting, he said his is not adjustable. My pedal is not stiff at all. I'm done with this thread.
06 CBR 1000RR
post #23 of 33 Old 07-30-2011, 04:58 PM
oxstang's Avatar
I'm using a Lokar cable but can't remember who made the bracket.
oxstang is offline
post #24 of 33 Old 07-30-2011, 09:30 PM
I'm running an 86 throttle cable on my carbed 351w setup in my 87 lx, the cable works fine and the pedal isn't stiff at all.
red73fastback is offline
post #25 of 33 Old 07-30-2011, 11:14 PM
KBRoadrunner60's Avatar
How did you get that to work? Is it the TC bracket that allows you to use different year cables? Like where they bolt on, or snap into the cable side of the bracket?
I guess they might be the same, I was told by "86" that if you buy a stock cable, the 85 auto will work, and the 85 manual will not fit on a Holley carburetor. So I did what he said...But what do I know, I'm just a girl...
1985 GT/351 Stroker/G-Force T-5 Transmission.
1968 Plymouth Roadrunner
KBRoadrunner60 is offline
post #26 of 33 Old 07-31-2011, 01:52 PM
I used the throttle cable bracket from the 86 and an edelbrock adapter plate to mount it to a stealth intake manifold, seems to work well.
post #27 of 33 Old 06-09-2013, 09:56 PM
pullinboost's Avatar
Anyone got anymore pictures of setups?
pullinboost is offline
post #28 of 33 Old 08-21-2015, 05:15 AM
ndmus88gteng's Avatar
Trader Feedback: (135)
google searching for a Throttle cable to go on a Pro-M 4 hole throttle body, google search always leads back to the Corral !! haha
for a 427 dart with a super-vic efi intake. in my 88 GT
will a stock bracket (ie 85 auto ) work ? is it the same setup as a carb engine ?
I would rather have a Lokar cable and some sort of bracket , but I've never setup a carb engine .
can anyone help me out
Thanks a lot
Rick
88 hatch 427 Dart FordStrokers,Tmoss ported SuperVic, Hi-Port 225's , Freezy custom cam, Pro-M engine management system with cnp, Aero fuel pump wiring, alt upgraded wiring, Flex-a-Lite 52185 radiator/fan combo, T56 Magnum kit , built 8.8 rear-end 3:73 with 31 spline axles welded 03 Cobra center section.
might be ready to dyno and run it by next summer of 2017,LoL I hope!!
Daily: 2012 F-1Fit'y 5.0 livernois tune coming soon one Day , I hope. nope traded oct 15-16 for a new 2016 supercrew.
ndmus88gteng is online now
post #29 of 33 Old 08-21-2015, 07:53 AM
GilroyRacing's Avatar
Trader Feedback: (111)
I used a lokar cable on my fox with a carb
91 Fox
R.I.P. 347: 1.43 60' 6.78@101.30 1/8th 10.64@127.84 1/4
302 1.59 60' 7.63@88.19 12.06@110.58
GilroyRacing is offline
post #30 of 33 Old 08-21-2015, 03:21 PM
Joeyman's Avatar
We used the stock EFI bracket and throttle cable. Just make the cable loop then put it on the stud.. you have to trim a little off the rear of the bracket.
Works great
Joeyman is offline
post #31 of 33 Old 08-22-2015, 04:45 AM Thread Starter
Wicked03GT's Avatar
Damn...This thread is still cooking?
You only need two parts...
I run this bracket without the return springs setup, mainly because if you run them the throttle is still as hell! And I don't plan on drag racing a lot. My pro system carbs has dual springs on it already anyways.
SBC BBC Holley 4150 4160 Series Chrome Billet Aluminum Throttle Cable Bracket | eBay
Then for the cable I run the Lokar 1000HT, I picked up the mindnight series on the newest build because the black stainless cover looks cool.
post #32 of 33 Old 08-22-2015, 05:07 AM
Wow I need that! Looks so bass as$! Thanks for the this.
Tronics is offline
post #33 of 33 Old 08-22-2015, 10:34 AM
1995gtCPE's Avatar
Trader Feedback: (34)
24in cable?
80 coupe, A4 347, Bullet hyd roller, ported 11r 190's, ported Super Vic, HPI e85 carb, Liberty TKO500/4.30
1995gtCPE is offline
