What does it mean when my car backfires through the carb??? - Ford Mustang Forums : Corral.net Mustang Forum
Old 07-08-2002, 06:55 PM   #1
QuikStang's Avatar
Trader Feedback: (15)
My car sputters and runs crappy below 3000 rpm and gives an occasional backfire through the carburator. Anyone know what gives......timing maybe? Thanks.
Mike
Here is my set-up:
'95 Lightning 351W block bored 30 over
Speed-O-Motive 393 stroker kit:
HI-NODULAR CAST 3.850 STROKE CRANK
5.956 STAGE 1 FORD 351W RODS w/ARP WAVE-LOC BOLTS
TRW forged pisions (flycut for valve reliefs)
Moly Rings
Clevitte Bearings
Edelbrock Performer RPM 1.90 aluminum heads (stud mount)
Crane 1.6 Roller Rockers
Holley Classic Double Pumper Carb (650cfm) just had fresh rebuild
Edelbrock Performer RPM Dual Plane lower
K&N carb filter
Mallory Wires
MSD Pro-Billet Distributor
MSD 6A Ignition Box w/Blaster Coil and Soft Touch Rev Control
Motor assembled with ARP hardware on heads, main caps and rods.
Brand new timing gears
Summit Racing SFI harmonic dampener (351W)
NOS Cheater System w/ bottle (system not connected)
QuikStang is offline
Old 07-08-2002, 08:04 PM   #2
Timing is way too retarded.
revac7 is offline
Old 07-08-2002, 09:28 PM   #3
QuikStang's Avatar
Too retarded, how about too advanced? What are your thoughts.
Mike
Old 07-08-2002, 10:29 PM   #4
Sounds like too rich....busted or wrong powervalve.
Check the condition of the plugs.
__________________
Resident grump and smart...
damage is offline
Old 07-08-2002, 10:38 PM   #5
91NOTCH's Avatar
I once put on a distributor on 180 degrees off. wouldn't start and would blow out out the carb after trying to turn it over. Check that distributor.
91NOTCH is offline
Old 07-08-2002, 11:33 PM   #6
QuikStang's Avatar
All very good inputs. The carb has just been rebuilt so is there still a chance of a bad power valve? I'll check into each of those and let you guys know. Thanks.
Mike
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
