Oil level sensor leakingon 5.0 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 10-16-2010, 04:56 PM Thread Starter
I have a leak right at the sensoron my 5.0 and was wondering if this is usually just the gasket, sensor, or both? There was no impact of any kind just has a leak. Can the gasket and/or the sensor be replaced w/o removing oil pan? Is this a common leak area?
91 GT Conv:Triple Black
H/C/I, 3.73's, T5Z - 12.4 @ 110
89 Corvette L98 - Bolt Ons - 12.90 @ 106
Brett 91 GT CONV is offline
post #2 of 9 Old 10-16-2010, 08:17 PM
jd-hart's Avatar
Trader Feedback: (25)
Those are known for leaking....Most people just remove the sensor and close off the hole. I put a brand new one in from LateModel and it leaked in 2 days. You DO NOT need to remove the oil pan.
jd-hart is offline
post #3 of 9 Old 10-16-2010, 08:27 PM
306Guy's Avatar
Trader Feedback: (64)
If you remove it will you lose a gauge or will it throw a CEL code?
Originally Posted by 91terry85 View Post
waxmaster,
that was my nickname in HS
306 - KB Hypers, GT40P's, LT, GT40 Tubular, 70mm TB, 90mm MA, Pulleys, T-5, 3.73's...I'm sure there's more...
306Guy is online now
post #4 of 9 Old 10-16-2010, 09:18 PM
Mine leaked right through the sensor where the connector plugs in.
The gaskets are usually pretty good and shouldn't leak from there unless it's maybe loose.
I bought a replacement sensor from Ford about 11 years ago and it hasn't leaked since then.
They aren't cheap to buy these days I think.
8950HO is offline
post #5 of 9 Old 10-16-2010, 11:39 PM
jd-hart's Avatar
Yes, you will lose the low oil light that comes on when the oil is low. But there will not be a light that stays on.
jd-hart is offline
post #6 of 9 Old 10-17-2010, 08:16 AM
Trader Feedback: (48)
NO CEL X2!!!
midnightrider is offline
post #7 of 9 Old 10-17-2010, 08:25 AM
Mine has been gone since I put a Canton pan on. Never really needed it anyways, I check my oil regularly.
1994 Ford Mustang GT - 331ci, Probe SRS flattops, Twisted Wedge Heads, Track Heat Intake, 75mm TB, AFM Powerpipe, 80mm Pro-M MAF, 30# injectors, F303 cam, 1.6RRs, BBK longtubes, MAC O/R H-pipe, Flowmaster catback, 50-150 NX kit, TwEECer R/T
NEohioSTANG is offline
post #8 of 9 Old 10-17-2010, 11:37 AM Thread Starter
What did you replace, the sensor or gasket? What do you use the close it off if I decide to get rid of it?
post #9 of 9 Old 10-18-2010, 10:00 AM
Luch's Avatar
I would get rid of it. You are almost guranteed problems with that thing down the road. I purchased the plug right from NAPA; it looks like a big oil drain plug. I had the information but can't find it at the moment, try the search it will come up for certain.
Luch is offline
