GT40P combo dyno numbers. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 09-28-2010, 05:25 PM Thread Starter
Just had my car dynoed the combo is stock GT40p heads with new springs, F303 cam, cobra intake, it made 277hp and 307tq. Only problem I had was with the FRPP headers, they fit the heads great, but the x-pipe would not bolt up to it. Anyone else have that issue?
93 Lx
06 tundra DD
08 road warrior
rdy2run is offline
post #2 of 13 Old 09-28-2010, 05:51 PM
warriorpluto's Avatar
Trader Feedback: (15)
good numbers hope to have similar. i have same setup except i have a b303 cam in mine. does it run hard?
warriorpluto is offline
post #3 of 13 Old 09-28-2010, 06:01 PM
Michael Yount's Avatar
tmoss has a GT40P combo, ported (lower) Explorer intake, stock HO cam, the other expected bolt-ons -- 277/330 at the wheels.
Michael Yount is offline
post #4 of 13 Old 09-28-2010, 10:00 PM
Stroked87Coupe's Avatar
I had the same EXACT setup! Stock bottom end, GT40P, F303, 1.6RR, Explorer intakes, shorties and put down 276RWHP/310RWTQ.
DSS 331, AFR 185's, Vic. Jr., Comp XE282HR, Barry Grant 650, Long tubes, PA Super Comp C4, 4.10's
11.49 @ 119
1.72-60'
Stroked87Coupe is offline
post #5 of 13 Old 09-29-2010, 12:14 PM
2000 explorer motor, crower 15511, trickflow springs, 1.7 rollers, mac longtubes, just a water pump and alt for accessories, cobra crank pulley, electric fan, and it did 293rwhp/333rwtq on a dynojet STD.
1993 mustang lx coupe "the stocker"
MIKE88 is offline
post #6 of 13 Old 09-29-2010, 01:25 PM
Bullitt95's Avatar
That's 284/323 SAE which is still very good for a GT40P combo.
2006 GT Deluxe - 5MT - 12.67 @ 108.61
310rwhp 328rwtq with simple bolt-ons
Bullitt95 is offline
post #7 of 13 Old 09-29-2010, 04:51 PM
tmoss's Avatar
Trader Feedback: (47)
Nice - you'll like it.
I no longer have to pass the sniffer due to age of the car, so my stock low-mile Cat is comming out for an un-catted H and a 15511 cam will be installed as well. We'll see what happens then.........
little more duration and lift with essentially the same recommended ICL (109 vs 110), not sure how ramps will compare. I actually saw one cam guy recommend putting it in a 106......
Tom Moss
tmoss is offline
post #8 of 13 Old 09-29-2010, 09:16 PM
Quik_Stang's Avatar
Anyone have any input on the X-pipe not fitting the FRPP shorties? I have the same headers and now that has me worried.
Quik_Stang is offline
post #9 of 13 Old 09-30-2010, 12:19 AM
89slowgt331's Avatar
Trader Feedback: (22)
I have the ford racing shorties with a bassani x pipe, fit was great.
89slowgt331 is offline
post #10 of 13 Old 09-30-2010, 10:52 AM
Formerly known as jbj302
NotoriousNotch's Avatar
Trader Feedback: (51)
I hope my numbers come out similar. I have some GT40's(iron), steeda#18, 1.7rr's, and explorer intake.
NotoriousNotch is offline
post #11 of 13 Old 09-30-2010, 11:12 AM
2cammer97's Avatar
One benefit of the GT40P's is they bump compression a little. I have similar combo to yours: stock 78k mile shortblock, GT40 heads, Explorer Intake, 1.7 rr, Crane 2031 cam (.513/.529, 214/220, 112), 70mm TB, AFM intake pipe, Pro-M 77 MAF, 24 lb injectors, BBK longtubes, BBK catted h-pipe, Dynomax Ultraflo Catback, SCT chip.
I had my car tuned last week and made 262 rwhp / 303 rwtq SAE corrected. My cam is pretty mild since I still have to pass the sniffer for emmissions and driveability was a top priority. I think I left a little power on the table by not having TMoss port the lower intake and by not degreeing the cam (just installed it dot to dot on the Comp timing chain).
Post up your dyno results once you get them.
Marcus
'99 Jeep Wrangler Sport 4.0L - offroad toy
2cammer97 is offline
post #12 of 13 Old 09-30-2010, 12:16 PM
My heads are 58cc on stock bottom end with 82K miles. I'm just doing this until I get everything I need for my 347 build.
post #13 of 13 Old 09-30-2010, 12:42 PM
2cammer97's Avatar
If they are 58cc I believe they are P heads. I think are regular GT40 heads are ~62cc like stock E7 heads.
