What spark Plugs are better? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 25 Old 11-03-2009, 03:33 PM Thread Starter
Question What spark Plugs are better?
I have heard Autolites are good. Any others? Motorcraft? Platinum or Copper? Or does it really matter what kind?
1987 5.0 GT stock 212xxx miles on the car, less than 100,000 on the engine.
Colascstang is offline
post #2 of 25 Old 11-03-2009, 04:19 PM
Autolites FTW
My DIE HARD Ford buddies will tell you the MotorCrafts are the way to go-
Copper or Platinum? Depends one what you are doing with them...
CNCOX is offline
post #3 of 25 Old 11-03-2009, 05:48 PM
autolites work fine, copper for best spark. Platinum last longer, but don't combine platinum with an MSD ignition.
slo5oh is offline
post #4 of 25 Old 11-03-2009, 06:05 PM
chvyeter's Avatar
ngk for anything you run nitrous on
8.0 @ 88 on motor, old 306
7.0 @ 100 on new engine combo
6.4 @ 108 letting out twice on bottle.
11.2 @ 126 in 1/4 on motor
chvyeter is offline
post #5 of 25 Old 11-03-2009, 10:08 PM
School me... What's the deal with Platinum and MSD Ignitions? I think I have heard this before.
CNCOX is offline
post #6 of 25 Old 11-03-2009, 10:24 PM
Formerly MustangSandi
Ourobos's Avatar
Trader Feedback: (116)
Any platinum plug I've EVER ran on a V8 caused it to miss terrible.. Those were designed for 4 bangers.
03 Marauder (392/402)
86 Bronco (408w)
Lingenfelter CTS-V
Ourobos is offline
post #7 of 25 Old 11-04-2009, 01:20 AM
I guess I've never ran into it because I haven't ran them...
You ;earn something ever day though.
CNCOX is offline
post #8 of 25 Old 11-04-2009, 10:14 AM
Trader Feedback: (33)
That's close to the dumbest thing I've ever read here.
I like Motorcraft coppers.
2005 F250 Super Duty Harley Davidson True Blue
1997 SVT Cobra Pacific Green
1995 5.0 GT Dark Forest Green
If you aren't living on the edge, you're takin' up too much space!
PGreenSVT is offline
post #9 of 25 Old 11-04-2009, 10:19 AM
Hence Sarcasm
4 Bangers and V-8 have are a completely different engine all together- ddin't you know. Especially in the ignition department! HAHAHA
Although I have heard people make comments about Platinums and MSD. Anyone want to explain that one to me- seem kinda far fetched, but crazier things happen all the time.
CNCOX is offline
post #10 of 25 Old 11-04-2009, 10:28 AM
My experience is that keeping the plugs fresh and good condition will result in good service. When I was racing, there were some brands that performed better than others (lower ET, longer life, etc), but changing camshaft, heads, etc would lead to another brand that ran better. So, my recommendation is that unless you are able to actually measure performance differences in brand to brand or design to design, just simply plan on making them a part of your upkeep program.
On my early 289 stuff, I normally found that the Nippondenso, that looked suspiciously like the Accel plugs worked best. I also used Bosch. Motorcraft, Autolite/Fram, and AC performed satisfactorily. Champion typically did not fair as well. But brand to brand differences can also be based in the heat ranges being slightly different too. All sorts of things can feed in to the equation. On my drivers I typically change out once a year. On project stuff, it may be once every 6mos or so. On my race car I would start the season with a fresh set and oil. Then about mid season, when ET's began to drop off I would put in a fresh set, and change the oil again.
Fresh and new is the sure bet.
a plug for a 4 cylinder versus 8 cylinder! The cylinders do not how many neighbors they have.
When platinum plugs first came out (circa '84), we would get returned sets all the time. we always attributed the issues to non adjustable gap and heat range problems. we took back more than few for sure.
as they began coming more and more as original equipment, the problems began going away as the engineers (auto company and spark plug company)began getting a better handle on the designs and coverage.
buddy rawls is offline
post #11 of 25 Old 11-04-2009, 10:30 AM
Ourobos's Avatar
Ever ran them? If not, you're the dumbest ape on earth.. Give them a try, jackass.
First few threads from a simple search for 'platinum' :
Why stay away from platinum spark plugs? gt40p
Bosch Platinum Spark Plugs (flame)
Spark Plug recommendations -- Anyone know about the Bosch Platinum +4's?
86 Bronco (408w)
Lingenfelter CTS-V
Ourobos is offline
post #12 of 25 Old 11-04-2009, 11:08 AM
ustahava67's Avatar
Trader Feedback: (23)
Autolites WERE a good choice .... until they started making them in China. Now I run NGK or Motorcraft
Romans 12:2 , 86 GT Bracket Car, 347 carbed/Vic jr's/Parker/ProSys 780/C-4,10.63 @ 125 bullets & Slicks, My dyno is 1320 ft. long.
ustahava67 is offline
post #13 of 25 Old 11-04-2009, 11:50 AM
chuckb's Avatar
I run autolite 104 coppers.
anyone know the NGK equivalent?
1993 Black & Grey 5.0L 5sp - Nothing but notch!
Edelbrock Perf 2.02/1.6s & Crane Gold 1.6RRs. RPMII & 3722 cam.
Bilsteins & MM stuff. 3.73s & Alum DS. BBK LTs/H pipe/Flows etc.
Dyno tuned/stock 19lb injectors 305rwhp/306tq.
chuckb is offline
post #14 of 25 Old 11-04-2009, 03:26 PM
ABN2060's Avatar
Motorcraft
Mike
'91 SSP Coupe (Cop motor, cop tires, cop suspension, cop shocks and runs on regular gas)
ABN2060 is offline
post #15 of 25 Old 11-04-2009, 05:40 PM
Originally Posted by CNCOX
School me... What's the deal with Platinum and MSD Ignitions? I think I have heard this before. .
http://www.msdignition.com/forum/showthread.php?t=3016
msdtechsupport2:
"We do not recommend using any platinum or any other “hype” plug when using the MSD system as problems can occur. Platinum plugs can retain heat and cause pre-ignition problems; they also have small electrodes that can burn up prematurely due to the added heat of the MSD system..."
slo5oh is offline
post #16 of 25 Old 11-04-2009, 10:35 PM
Awesome, that's what I wanted to hear.
Learn something everyday. I always heard to stay away from them, just never bothered to learn why.
thanks
CNCOX is offline
post #17 of 25 Old 11-04-2009, 10:42 PM
MurPHy4570's Avatar
You DO realize that all of the V8s Ford has made in the last decade or so have come with Platinum sparkplugs, right?
Try using a narrower brush when you make a comment next time, it'll save you some headaches.
"Our Country! In her intercourse with foreign nations, may she always be in the right, but our country right or wrong."
- Commodore Stephen Decatur, Norfolk, Virginia, April 4, 1816
MurPHy4570 is offline
post #18 of 25 Old 11-04-2009, 10:47 PM
Ourobos's Avatar
You do realized Ford hasn't put a pushrod V8 in a Mustang in the past decade also, correct? This is a Mustang site, last I checked. Try a platinum plug on one and see for yourself, or join the other knuckle dragger.
86 Bronco (408w)
Lingenfelter CTS-V
Ourobos is offline
post #19 of 25 Old 11-04-2009, 10:51 PM Thread Starter
Thanks guys for the replies. I think I will give the Motorcraft ones a try. The ones in it are the Bosch Plat 4 plugs. I have not heard great things about using these in Foxes, but what I heard could be BS. Who knows.
post #20 of 25 Old 11-04-2009, 10:53 PM
Ray III's Avatar
I don't see the part where they only work on 4 bangers.
this post property of RAYMOND
Ray III is offline
post #21 of 25 Old 11-04-2009, 10:55 PM
Ourobos's Avatar
A generalization.. I've never had a problem with them in a 4 banger.
86 Bronco (408w)
Lingenfelter CTS-V
Ourobos is offline
post #22 of 25 Old 11-04-2009, 10:58 PM
I used platinum's on my mainly stock 91 5.0 and then used NGK platinums when I switched over to cobra intake, gt40 heads and e-cam. Never had any issues with 55K total miles b/w both combos.
mlb585 is offline
post #23 of 25 Old 11-04-2009, 11:04 PM
platinum plugs are crap, but the number of cylinders has nothin to do with it. they are for mild performance motors in the average car where the owner just wants a plug that last long while providing adequate spark. copper arcs much better for performance
1988 ASC/McLaren,
1969 Mustang GT 390 handles microscopically better than a cruise ship
2008 Shelby GT500 Charcoal deleted stripes
kbmclaren is offline
post #24 of 25 Old 11-05-2009, 12:51 AM
OMG! I forgot.. I have had experience with Platinum 4's... Holy shat they suck arse.
CNCOX is offline
post #25 of 25 Old 11-05-2009, 11:17 AM
Accel U-Groove. I use bosch platinum's in my dd. Not to hyjack but anyone use E3's?
You also are not supposed to run platinum's with boost.
BTW I have NGK platinum's in my 94 cobra....thats pushrod....thats modified.....it's not a 4 banger.....it runs fine???
paxton50mustang is offline
