Coolant Sending Unit - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 09-16-2009, 05:23 PM Thread Starter
where is it located?
I tried search button but after 30 min my eyes gave up! lol
sorry if this has been asked before.
Thanks!
1989 Mustang GT - Stock...for now!
2001 SVT Cobra Convertible (sold)
1993 SVT Cobra (sold)
1996 LT4 Corvette (Sold)
01_SVT_Trublu is offline
post #2 of 12 Old 09-16-2009, 05:37 PM
Dean Scheidt
SLO 5-OH's Avatar
Trader Feedback: (53)
On my 89 5.0, the coolant temp sending unit for the gauge is near intake runner # 5. There is also a coolant temp sending unit in the metal heater line that is probably for the computer.
1989 Mustang GT - original owner
1/8-mile: 6.57 @ 102.67
1/4-mile: 10.40 @ 128.13 (1.37 60')
425 RWHP:
, TW 205 heads, tmoss TFS Box-R intake,
AOD,
8" converter, 4.10's, Team Z Suspension, M/T 26" ET's, full interior, 3,340 lbs race weight. Tuned by Willie at
SLO 5-OH is offline
post #3 of 12 Old 09-16-2009, 05:41 PM
ABN2060's Avatar
Overflow or temp?
Mike
'91 SSP Coupe (Cop motor, cop tires, cop suspension, cop shocks and runs on regular gas)
ABN2060 is offline
post #4 of 12 Old 09-16-2009, 05:41 PM Thread Starter
perfect! that's what I have. I forgot to include my sig when i created the post!
thanks!!
post #5 of 12 Old 09-16-2009, 05:43 PM Thread Starter
Originally Posted by ABN2060 View Post
Overflow or temp?
my temp gauge is pinned to the floor and does move when grounded. Not sure if its temp or overflow. I read on the forums that it may be the temperature sending unit so thats what i picked up from ford
post #6 of 12 Old 09-16-2009, 05:50 PM
ABN2060's Avatar
Originally Posted by 01_SVT_Trublu View Post
my temp gauge is pinned to the floor and does move when grounded. not sure if its temp of overflow. I read on the forums that it may be the temperature sending unit so thats what i picked up from ford
OK. The low coolant sensor is just for the idiot light. Not sure which sensor is for the gauge.
Mike
ABN2060 is offline
post #7 of 12 Old 09-16-2009, 06:46 PM
Joel5.0's Avatar
In front of injector #5.
ACRONYMS:
LUK=Let Us Know, GL=Good Luck, LMK=Let Me Know, JIC=Just In Case, BTSTDTRT=Been There Seen That Done That Repaired That, YCYDYP=Your Car Your Dough Your Prerogative and the classic... DILLIGAS=Do I Look Like I Give A S***
1986 Mustang GT w/T-Tops
NOW: 5.0L Stock shortblock, X303 Cam, SP Offy. Port-O-Sonic, 700 cfm DP Holley, 289 '66, 1.7 RR, Richmond Gear 4+1 Trans., Centerforce DF kit, 2.73 Gears
WIP: 3.90 Gears(Motive Performance), LS Overhaul (FRPP), Adj. LCA's (New Design Granatelli Aluminum), Adj. UCA's (Granatelli), Caster/Camber Plates (MM), Subframe Conn. (MM) T-Top weatherstriping and rear braces bodywork
Joel5.0 is offline
post #8 of 12 Old 09-17-2009, 12:36 PM Thread Starter
thanks for the visual! I never would have foound it tucked in there!
post #9 of 12 Old 09-17-2009, 01:25 PM
another ?
where's the ect on a cobra intake?
rippedroller is offline
post #10 of 12 Old 09-17-2009, 01:31 PM Thread Starter
on the passenger side of the intake. it screws into the metal pipe that runs along side the injectors. thats an easy one to change
post #11 of 12 Old 09-17-2009, 02:41 PM
MFE
Super Moderator
MFE's Avatar
ECT is a sensor for the computer, it goes in the heater pipe bolted front to back on the passenger side of the intake. The Coolant Temp SENDER for the gauge is the single wire unit that 's pictured above, which threads into the intake itself.
MFE is offline
post #12 of 12 Old 09-19-2009, 12:27 AM Thread Starter
Just swapped it out! Gauge working again! This SITE ROCKS!!!
