Do I need to use sealer with paper gaskets? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 08-20-2009, 02:39 PM Thread Starter
4 eyed mustang's Avatar
I have a felpro engine set i am using for my engine rebuild. Do I need to use any type of sealer on the paper gaskets for the timing cover, water pump, etc.? If I do what do you recomend using.
Also what type of sealer is recomended for the front and back of the intake instead of the cork gaskets?
thanks
1986 GT 5spd, Vortech S-trim, 3:55, BBK longtubes and H-pipe, Subframe connectors, Mac mufflers, Accel Coil, Custom paint, Hurst short throw, Rebuilt bottom end, GT40 irons, TFS1, Cobra upper and lower, 42's, LMAF, SCT chip tuned by SGS Automotive, AEM Meth and widband, UPR Powerpipe 26000 miles.
4 eyed mustang is offline
post #2 of 7 Old 08-20-2009, 02:44 PM
Red Fox's Avatar
thanks
I just use black RTV on the intake to block rails. I spread it on nice and even all the way across, allow it to set for 10 min until it has a tacky feel then drop the intake on. I use four old intake bolts with heads cut off so installed in the corners so they become like locating dowels.
Member of Corral.net since 1999. Disagree with a mod and get your entire 15+ feedback history deleted.Brilliant!
'89 Mustang GT '05 Ninja ZX-10R '91 MR-2 Turbo '72 Jeep CJ-5
Red Fox is offline
post #3 of 7 Old 08-20-2009, 05:43 PM
humbleLX's Avatar
i use "the right stuff" it holds like oem for water pump, lower intake to heads(especially front and back lower instead of cork), thermostat housing, etc. been using it since it first came out and never had a leak.
just make sure the sufaces are prepped, cleaned, and dry.
Black & Tan aka Scream Puff
hawaiiperformancemustangs.com/forum/index.php?topic=10231.0]
humbleLX is offline
post #4 of 7 Old 08-20-2009, 06:11 PM
Hylomar gasket sealer would work great for the timing cover,water pump gaskets and intake gaskets.
I used silicone rubber lower intake end seals and have no leaks.
8950HO is offline
post #5 of 7 Old 08-20-2009, 06:37 PM
Banned
Trader Feedback: (-1)
i use rtv black on my lower intake ends, and on the timing cover
abd rtv blue on the water pump. no paper gaskets for me
post #6 of 7 Old 08-20-2009, 07:15 PM
Dr.Shift's Avatar
Trader Feedback: (27)
I use grey silicone on the front and back of the intake and throw the rubber or cork ones away and i also use grey silicone everywhere else and no leaks
Dr.Shift is offline
post #7 of 7 Old 08-20-2009, 09:55 PM
Use the FelPro gaskets and spray them with HiTack or brush with Ford PerfectSeal!
Works great and no leaks or mess.
andone1 is offline
