Why does my oil look like metallic paint?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 206 Old 07-15-2009, 12:28 PM Thread Starter
Trader Feedback: (43)
In the past when I changed the oil in my cobra, the oil looks like brand new. This past winter I added AFR 165's and a cam and after putting maybe 200-300 miles on the new combo, I decided to change the oil and it looks exactly like brown paint with gold metallic. I'm not talking chips or anything, I mean exactly like metallic paint. The metallic is super fine and all gold and every ounce of the oil was full of it. If you stirred it, it would get that light and dark swirl look like paint. I emptied my pan into a jug in the sun and all of the oil just sparkled gold. The only thing gold in my motor is the AFR valve guides. Please tell me that this is part of guides breaking in or something and that I don't have a set of bad guides in my AFR's. I spent countless hours getting the geometry right, so that should not be the problem. It runs perfect and the valvetrain is dead silent, but this oil has me freaked out, especially since my son just added trick-flows to his GT and he has more miles than me and we changed his oil and it was perfectly clear. Is my filter going to catch all of this stuff or is it running this crap thru all of the bearings of my 2,900 mile motor. Should I be concerned or just keep running it? Thanks!!
Just an old carpenter with a 94 Cobra and a Son with a nasty 85GT! I'm Show and he's Go!!
XSPOWER is offline
post #2 of 206 Old 07-15-2009, 12:42 PM
Nutzz's Avatar
Trader Feedback: (39)
Either bearing or guides IMO. Best thing to do IMO is put fresh oil in drive it around maybe 50-60 miles Pull the filter and dump it and see if you still have those shinny gold stuff. I have owned 2 sets of AFRs and never had that issue. Also never heard of anyone complaining about bad valve guides on AFR's..Valve springs o yeah..I hope you get this solved soon.
TOO_NUTS Racing
N/A- Pump Gas- 408 Clevor - 6.08@112.92.
Nutzz is offline
post #3 of 206 Old 07-15-2009, 12:48 PM Thread Starter
Type "worn afr valve guides" in the search box and you will see why I am spooked.
XSPOWER is offline
post #4 of 206 Old 07-15-2009, 12:52 PM
M1Tanker's Avatar
Did you cut the filter open to see if it was in there too?
Nothing makes you feel better about yourself quite like an episode of Hoarders
M1Tanker is offline
post #5 of 206 Old 07-15-2009, 12:56 PM
n2089's Avatar
Trader Feedback: (28)
time to take it all back apart .
94 gt blown
97 cobra blown
n2089 is offline
post #6 of 206 Old 07-15-2009, 12:56 PM
Are you using a brass gear on the dissy shaft?
My84GT4vho is offline
post #7 of 206 Old 07-15-2009, 12:58 PM
67mike's Avatar
You might want to look at the distributor gear as well????? Could be incompatable material with cam????
Also, what oil are you running? I really suggest synthetic, for many reasons.
1967 GT Coupe, 4 speed toploader, 393W, Custom Cam, Canfield Heads, Vic Jr Intake, Crane Ignition, Holley Ultra Avenger Carb, etc........
2003 GT Convertible, K&N cold air system, Magnaflow cat back, auto...MINT...Loving it!
67mike is offline
post #8 of 206 Old 07-15-2009, 02:02 PM
87TurboGT's Avatar
You know what other type of metal resembles gold? The copper in your main, rod, and cam bearings. One day I went to change my oil and noticed this exact same problem. Cut the filter and it was littered with material. Pulled the engine and tore it down. Cam and rod bearings = FAIL.
87TurboGT is offline
post #9 of 206 Old 07-15-2009, 02:42 PM
Michael Yount's Avatar
Cut the filter open Aaron - and don't drive the car again until you get it figured out. That's definitely not normal. My oil change post head change looked just like any other. I'd also go online to Oil Analyzers (google it) and select the link to get them to send you an oil sample kit. You'll collect a sample (hopefully you saved it) and ups it to them (comes prepaid/packaged). They'll do an analysis for you. Sounds like bronze/copper to me.....either way, not so good.
Michael Yount is offline
post #10 of 206 Old 07-15-2009, 02:52 PM
M1Tanker's Avatar
^ I was going to suggest that. You can also pick that oil analysis kit up at your local John Deere dealer (thats is where my step father gets his at for his semi. It started detecting a bearing failure 2 months before it happened).
M1Tanker is offline
post #11 of 206 Old 07-15-2009, 03:00 PM
Blackstone is another oil analysis lab - but I prefer Oil Analyzers. I'll try and get a link.
post #12 of 206 Old 07-15-2009, 03:03 PM
if the filter element and the botom of the oil filter housing look like a gold mine, its bearings and usually a rod bearing as they will tear up in an instant
strokeme is offline
post #13 of 206 Old 07-15-2009, 03:16 PM
Here's the link Aaron to order your test kit - http://www.amsoil.com/catalog.aspx?GroupID=685
Woody - he's got an original 94/5 Cobra with only 2900 miles on the shortblock. He did a major head/cam/intake/etc. upgrade - but never touched the bottom end -- which was working perfectly before. I think that's why folks are wondering about cam gears, guides, etc. Of course a bearing can go at any time....but seems unlikely in this case.
post #14 of 206 Old 07-15-2009, 03:55 PM
87TurboGT's Avatar
didn't notice the 2900 miles. That still doesn't change my thoughts though. He couldve very easily dropped something in the motor, dirt or metal shavings, that would cause a failed bearing. Did he change the oil right after the head swap? I'm no expert but I've always heard that ethelyne glycol can wipe bearings out in no time. Also he said when he changed the oil in the past it looked like new? How many times do you change the oil on a car with 2900 miles?
post #15 of 206 Old 07-15-2009, 03:55 PM Thread Starter
Like Michael said, the stock shortblock only has 2,900 miles on it and everything was flawless and oil changes were crystal clear until the head/cam swap. I still use the stock steel dizzy gear also. I removed the dizzy and both gears look like new. I cut the oil filter open and spread the paper fins apart and there was no sign of anything, but the paper is all brownish so it could be full of that bronze and I may not see it. It appears so fine in the oil, it would not show up as flakes. Hopefully it didn't just go thru the paper in the filter and into the motor. Can someone explain how if the guides are failing, how does the bronze get into the oil. Does it get past the seals somehow or sucked into the cylinders somehow and past the rings?? I tried so hard to get this thing right the first time. Thinking about starting over makes me sick! Thanks for all of the help!
XSPOWER is offline
post #16 of 206 Old 07-15-2009, 04:04 PM
Trader Feedback: (18)
I'd imagine if it were the guides, it would come up into the valve cover area past the seals. Pop a valve cover yet?
justhereforinfo is offline
post #17 of 206 Old 07-15-2009, 04:48 PM Thread Starter
I havn't torn anything apart yet. I'm trying to find out how much it will cost to rent a back-hoe and how long it will take to did a hole big enough to shove it into. I don't handle failure very well, can you tell??
XSPOWER is offline
post #18 of 206 Old 07-15-2009, 04:54 PM
fix it
or
alternative is to sell it..
or pour in five gallons of gas in the seats and drop in a book of matches.
I have gone down the road that you are only now about to travel.
tires are the great equalizer
a degree wheel, EIGHT INCH dial caliper & adjustable pushrods should be just as normal as a 1/2" wrench in your toolbox
there aint no shortcuts to doing it RIGHT....
Kato Engineering is offline
post #19 of 206 Old 07-15-2009, 04:56 PM Thread Starter
Originally Posted by Kato Engineering View Post
fix it
or
I will fix it, but the other two options are tempting, especially the second one! If you see a big puff of smoke over Ohio, it's just me!
XSPOWER is offline
post #20 of 206 Old 07-15-2009, 05:03 PM
but doing that,
is a bad / poor example for your kids....
especially when the insurance payoff check comes in the mail...
post #21 of 206 Old 07-15-2009, 05:05 PM
pour the oil on to a paper towel and see more clearly what is in the oil that is drained out.....
post #22 of 206 Old 07-15-2009, 05:24 PM Thread Starter
Good idea, I'll try that!
XSPOWER is offline
post #23 of 206 Old 07-15-2009, 05:29 PM
if it is shiney but not copper,..
...it could be a pushrod rubbing on the hole in the head.
post #24 of 206 Old 07-15-2009, 06:13 PM
Coffee filters work pretty well too -- but you're better off having one of the analysis run Aaron -- you'll see exactly which counts are higher than they should be. I've used them many times - best $28 you can spend at this point. Post a pic of the engine bay for them Aaron -- it'll help everyone understand why you don't want to go back in....
post #25 of 206 Old 07-15-2009, 06:17 PM Thread Starter
Maybe I'm worrying about nothing. I went out and poured the oil thru a paper towel and got nothing. The weird part is just to look at the oil in the pan it just looks dark brown, but if you shine a bright flashlite on it , it gets the goldish metallic look. Now, here's the weird part. I took a couple of other jugs of oil that are out of my daily drivers and poured some out, it just looks black until I shine the light on it and if I stir it, it also has that sparkly look to it except much darker, I assume because it has 3000 miles on it and is dirtier. I took new oil and it is clear but real gold. Whatever is in the cobra's oil that makes it look metallic will not show up as particles on anything I try. I dipped a white paint stir stick in it and when you pull it out, it just looks like dirty oil/ not particles. Can it be that when oil gets contaminates from blow-by etc. that it makes the oil have that sparkly look and since my oil only had a couple hundred miles on it, it was still really goldish but had enough blow by to fog it up. This only shows up under a bright light or in the sun, which in the past I've never done before. It just seems weird that the old oil I have from other vehicles looks very similar to the cobras except much darker. It is all Penzoil 5w30. Maybe that is why the filter and drain pan showed no actual particles?? Or is valve guide wear so fine that it just colors the oil rather than put particles in it??
XSPOWER is offline
post #26 of 206 Old 07-15-2009, 06:24 PM Thread Starter
Thanks Michael!
XSPOWER is offline
post #27 of 206 Old 07-15-2009, 08:35 PM Thread Starter
Question?? If what I am seeing is ground up bronze, would it sink or float?? I poured some of the oil into a clear glass jar and let it sit. After sitting quite a while I shined the flashlight on the side of the jar and it was sparkly evenly from top to bottom with no pile at the bottom & nothing floating at the top. Is that a good sign??
XSPOWER is offline
post #28 of 206 Old 07-15-2009, 09:27 PM
Quit guessing and get the oil analyzed so you'll KNOW....
post #29 of 206 Old 07-15-2009, 10:39 PM
357poweredstang's Avatar
Agreed, then you'll know if it's the motor or the new parts....
If you go with that oil kit let me know and I can hook you up with some kind of discount since Im part of their preferred customer programs...
87 GT 306 machined/built by me..Windsor Jr heads, E cam, GT40, lt's, Tremec 3550 etc....Tweecer R/T tuned PLX wideband
Bunch of parts for sale..306, fully forged 347, 0 mile 357, Fully Forged 408, tremec trans, clutch, and more....
357poweredstang is offline
post #30 of 206 Old 07-15-2009, 10:41 PM Thread Starter
Thanks guys!
XSPOWER is offline
post #31 of 206 Old 07-15-2009, 10:54 PM
El_Diablo's Avatar
to bad your across the state from me....... if there is a metallic substance, it will sink after sitting and due to the slipperiness of oil it usually wont stick to items unless they're larger particals
another thing here is that the "gold" color your seeing is the oil, a good test would be to mix up the oil really well and then pour some through a coffee filter into a small container, you really only need a couple ounces, then very lightly so it doesn't rip, spray brake or carb cleaner on the filter to remove the oil from any particles that may be in your oil, this will give both you and us a better handle on what material that is in the system
another option is throw a new filter on it, new oil, then run the motor for about 15-20 minutes until its fully warmed up and give it one or two slow revs until about 3k rpms, then remove the filter and cut it open to check the media for any particles
btw, i wouldn't recomend penzoil at all, best oil for your car is royal purple and i dont say this just because of their adds, ive seen tests that prove the quality of their oil and ive seen quit a few bad results for amsoil, though still better than penzoil, just a friendly FYI, these were all privately done tests
El_Diablo is offline
post #32 of 206 Old 07-15-2009, 11:07 PM
Are you running alum rockers? They could be chaffing on the valve spring retainers. Sometimes the bolt on stuff doesn't clear the other bolt on stuff.
I hope I am right. If they are making contact and still need clearancing you can touch them up with a die grinder for clearance.
good luck,
railroad
99 Cobra Red and Charcoal, KB, Tri ax, 3.73, Alum flywheel and driveshaft, JBA shorties, Magnaflow X and catback.
Railroad is offline
post #33 of 206 Old 07-15-2009, 11:31 PM
why dont you just do all of your oil changes at nite with the lights off..
then you will not see anything weird.
post #34 of 206 Old 07-16-2009, 08:38 AM Thread Starter
That's a good one! I need a little humor at this point. Things could always be worse. I have to be thankful it lasted 200 miles!
XSPOWER is offline
post #35 of 206 Old 07-16-2009, 12:18 PM Thread Starter
El Diablo, The glass jar that I have about a 1/2 qt in sat all night and from what I could see I didn't see any settlings at the bottom of the jar. I didn't have any coffee filters,but I did have some of those white filter masks you wear when you spray paint, so I took one of those and poured most of the whole jar thru it. It took forever to run thru the filter. I sprayed the brake cleaner like you said to get all of the oil out and all that was left at the bottom were a few extremly fine specs, but none of them looked gold. They just looked like super tiny specs of dirt. I took a magnet and none of them stuck to it. Here's a odd one. I left about 1 inch of oil in the jar and if I shine a light up thru the bottom of the jar, the oil looks like clear new oil, but if I shine the light down thru the top of the jar and tip the jar so the oil is on a angle. it gets that metallic look. If it actually was full of small particles, there's no way it would look clear from the bottom would it? I have a show this weekend and next weekend, so I think since I put a new filter and new oil in it, I will drive it some and after the shows are done I will change it again and cut the filter etc and check it again. Thanks!
XSPOWER is offline
