Dyno Numbers After GT40 Head Swap!! - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
post #1 of 76 Old 06-25-2009, 08:34 AM Thread Starter
90Notch302's Avatar
Smile Dyno Numbers After GT40 Head Swap!!
Hey Corral, I finally got to Dez Racing yesterday to Dyno and tune my car. Here's what I did to it:
Swapped stock heads for GT40 Irons with 1.7 RR's and upgraded springs. Also added a 255 fuel pump, 24lb injectors with 75mm ProM, tossed the A/C.
Car still has stock cam and gt40intake is untouched.
263hp and 306ft/lb...
I'm thinking I'm right where I should be with my combo.
Let me know what your thoughts are and what my options are for some extra HP out of the intake over the winter. Thanks Corral.
Oh, and here's some pics of the build for the hell of it. Dyno vid coming soon.
STOCK:
EVERYTHING OFF:
NEW HEADS:
Also went ahead and painted the stock valvecovers:
Passenger Side:
Driver's:
Complete minus 75mm ProM:
Tremec 3550, Spec stage 2,Alm. Driveshaft, SteedaTri-Ax, 3.73's,65mmTB, adjustable FPR, BBK long tubes, BBK h-pipe w/o cats, Edelbrock exhaust,e-fan, 50/50 and 70/30 lakewoods, LCA's, Eibach drag launch,GT40upper/lower, GT40 heads, 1.7 RR's, 75mm Mass-Air, 24lb's.263hp 306ft/lb
90Notch302 is offline
post #2 of 76 Old 06-25-2009, 08:50 AM
white93pony71's Avatar
Trader Feedback: (23)
awsome #s.. thats what i made with almn gt-40s... i think something isnt right with mine...
white93pony71 is offline
post #3 of 76 Old 06-25-2009, 08:56 AM Thread Starter
90Notch302's Avatar
Thanks man. Yeah, Dez said we could probably get more out of them but it is my daily driver and I don't want to be dumping much more fuel through it just to pick up a couple more horses. It's currently running at 48 for fuel pressure. When we finished with the build, 99Exploder and I set the timing and fuel pressure just so that it would idle fine. Couldn't really tell what the timing was at because it was unreadable, but the fuel pressure was at 38. Got to Dez's and had only like 220 HP if that lol...Amazing what some fuel and correct timing will do.
post #4 of 76 Old 06-25-2009, 09:48 AM
89stang1's Avatar
great #s for gt40 irons and a intake no doubt!!
89 Mustang GT 333 STROKER Probe SRS 4cc flattop pistons, 10.7:1 comp., AFR 185 58cc Heads, Comp NX274HR Cus grind Cam, .550/.570, SCTII tune, PMAS 75mm chrome bullet, Accufab 70mm TB, 30lb inj, SCT Eliminator piggyback chip, BBK longtubes, OR H Pipe, Macs, ZEX NOS
http://photobucket.com/PICTURES89
89stang1 is offline
post #5 of 76 Old 06-25-2009, 09:54 AM
spydermandb's Avatar
i'd give the numbers a C for average...did you have a baseline before your swap?
but dyno numbers aren't that important, take it to the track.
-Robert
spydermandb is offline
post #6 of 76 Old 06-25-2009, 10:28 AM
89stang1's Avatar
Gotta disagree i would go with a B above average for sure LOL im going with those #s are RWHP not HP if so ive seen honest dynos with similiar builds making alot less, as for HP i agree with out a doubt if anything im more impressed by torque #s but most of all ET. For example ive beaten more than 1 500 RWHP 03 cobra with alot less HP
89stang1 is offline
post #7 of 76 Old 06-25-2009, 10:32 AM
Nutzz's Avatar
Trader Feedback: (39)
Nice numbers man!
TOO_NUTS Racing
N/A- Pump Gas- 408 Clevor - 6.08@112.92.
Nutzz is offline
post #8 of 76 Old 06-25-2009, 10:35 AM Thread Starter
90Notch302's Avatar
Numbers are RWHP and no I never dyno'd it stock. I probably had less than 200 RWHP before the heads, massair/injectors.
post #9 of 76 Old 06-25-2009, 11:16 AM
blackout50's Avatar
Trader Feedback: (18)
Bet closers to 230 before heads,MA and injectors. I Made 230ish with Cobra intake,24lbs,Longtubes,76mm MA,65mm tb and ran a best of 12.89 @ 104
no one knows. thats the issue with EFI, too much guessing.
wisdom from bolt-on-bandito
blackout50 is offline
post #10 of 76 Old 06-25-2009, 11:28 AM
US Army Active Duty
SVTCobra347's Avatar
Trader Feedback: (34)
Send the intake to tmoss.. clean up the exhaust bumps in the heads, and put a good cam in it over the winter and you'll really be having some fun!!
SVTCobra347 is offline
post #11 of 76 Old 06-25-2009, 11:37 AM Thread Starter
90Notch302's Avatar
Yeah, I plan on sending the lower to him over the winter. Will be speaking to him about it soon..
post #12 of 76 Old 06-25-2009, 12:02 PM
NotchAbove's Avatar
Camshaft is really your next step. Pull the lower, send out for porting, while that is out, swap the cam. Re-Assemble and hit the track !
1993 Reef Blue Notch
Thumper E7's|Cobra Intake|Crane 2031|FMS 65mm TB|90MM LMAF|30# inj|190lph|3.55's|V3 SCi|Moates QH/BE/EA
NotchAbove is offline
post #13 of 76 Old 06-25-2009, 02:24 PM
Project Reef Blue's Avatar
Congrats! Seems right on the money for that setup.
Stock Block 306", TFS 170, Systemax, F303, Novi 1220, Tweecer, Faceplated TKO 500, Mr. Freeze, 3100lbs
N/A: 332rwhp 332rwtq 11.44 @ 117mph; 6psi: 10.765 @ 128.31mph
Project Reef Blue is offline
post #14 of 76 Old 06-25-2009, 02:43 PM
NotchAbove's Avatar
Where did your timing end up at ?
post #15 of 76 Old 06-25-2009, 04:50 PM
That is an awesome combo.....
Her name is white lightning. She's loaded with some Griggs stuff, and a plant woody built for me.
onefastsvt is offline
post #16 of 76 Old 06-25-2009, 04:56 PM
Nitrous SSC's Avatar
Pretty good actually.
Just finished a build on a 308 with 9.5:1 comp GT-40 Irons and explorer intake. It did 265rwhp 300ftlbs. However it had an E-cam.
You're setup runs pretty dang good.
Bonneville 130 club member. (139.993) 11.48@123 in the 1/4.
Nitrous SSC is offline
post #17 of 76 Old 06-25-2009, 06:57 PM
Bullitt95's Avatar
Yeah, those numbers are in the ballpark for a GT40 set-up.
You might wanna put a heatshield around your air filter 'cause right now it'll be sucking in hot underhood air and that's not good for performance.
'64galaxie500 likes this.
2006 GT Deluxe - 5MT - 12.67 @ 108.61
310rwhp 328rwtq with simple bolt-ons
Bullitt95 is offline
post #18 of 76 Old 06-25-2009, 07:19 PM
kwikstang's Avatar
Trader Feedback: (43)
wow...seems a little high for your set up.
i'm running the same base pressure.
oh...btw...nice numbers bro.
92 GT 5sp w/ Thumper ported GT40s, Cobra intake w/TMoss ported lower, Crane 2031, On3 70mm, AIS water/meth, AFM PMS, flashACQ
stocking out 11/13
kwikstang is offline
post #19 of 76 Old 06-25-2009, 07:39 PM
privatejoker's Avatar
What kind of tuning was done?
privatejoker is offline
post #20 of 76 Old 06-25-2009, 08:20 PM
man, when you can afford it, get a custom cam for your set up with a ported lower. I will bet you can get closer to the 290-300RWHP with stock like driveablity.
post #21 of 76 Old 06-25-2009, 08:35 PM
8990mustang's Avatar
Good job.
GOT BOOST
8990mustang is offline
post #22 of 76 Old 06-26-2009, 08:00 AM Thread Starter
90Notch302's Avatar
Thanks everyone for the comments.
NotchAbove: Not sure if I wanna toss a cam in until I know what I plan on doing as far as power adders. Unless I can find one for cheap that is. I just don't want to have to swap cams more than once. Pretty sure timing is at 15.
Bullitt95: I'm gonna consider that heat shield thing.
kwikstang: That's what I thought too but Mike said if that's what it likes then just leave it like that.
privatejoker: Just basic fuel pressure and timing on the dyno.
onefastsvt: I know that my buddy 99Exploder(on here) has the same intake but ported and afr165's, custom cam and he made 306 rwhp I believe.
I think I'm gonna call Mike back and ask him about an issue I've been having since the tune. Whenever I'm cruising or getting on it and then I put the clutch in to slow down and brake to a stop, the car's rpm's just go straight down to 0 and the car dies. Can't figure out why. I'm thinking maybe a vaccuum leak? Anyone ever have the same problem?? Thanks again for all the replies.
post #23 of 76 Old 06-26-2009, 09:37 AM
nlped40's Avatar
Trader Feedback: (30)
It could be a vacuum leak but I had this problem once and it turned out that the TPS voltage was to low. I reset it and all was fine. Maybe this will help. BTW...really good #'s
Thanks Ed
1963.5 Ford Falcon Futura Sprint.
349 EFI, AOD, 8.8.
nlped40 is offline
post #24 of 76 Old 06-26-2009, 09:56 AM Thread Starter
90Notch302's Avatar
How do you reset the TPS? Thanks for the info.
post #25 of 76 Old 06-26-2009, 11:26 AM
Bullitt95's Avatar
He's not going to gain anywhere near 30rwhp with a cam change. He's be lucky to get 12rwhp from that so the remaining gains will have to come from porting the heads/intake.
post #26 of 76 Old 06-26-2009, 11:52 AM
Brian47's Avatar
Take it to NED or LVD and see what it runs. My car makes almost the EXACT same power, 265/295.
For comparison sake.
89 LX: Stock cam, E7s, Cobra intake, 3.73s and bolt ons... BESTS
12.56 et 107.4 mph: slicks, 12.53 et 108.2 mph: 17" ET Streets, 12.87 et 111.5 mph: 17" DRs, 12.95 et 109.2 mph: 18" radials
Brian47 is offline
post #27 of 76 Old 06-26-2009, 12:13 PM Thread Starter
90Notch302's Avatar
Definitly heading up to NED some time soon hopefully. I hear you can run slicks now on Friday night street nights...
It ran a 13.4 with everything in my sig except for the 65mm TB, gt40 intake, e-fan, full suspension, long tubes and exhaust. I'm hoping for mid 12's with a good 60'.
BTW Brian47: GREAT POWER for E7's!!
post #28 of 76 Old 06-26-2009, 12:18 PM
good job, nice numbers.
PROJECT T-BIRD....427....
95BadBird is offline
post #29 of 76 Old 06-26-2009, 12:23 PM Thread Starter
90Notch302's Avatar
Thanks!
post #30 of 76 Old 06-26-2009, 02:18 PM
89stang1's Avatar
Im gonna go with your IAC on that stalling problem, on my car if i dont keep my idle at 1000 rpms i stall under same conditions, and i mean 100 less rpms will do it so if u got ur idle set at 800 rpms u might wanna try to raise it a little? Also every vacuum leak i ever had when i pushed in the clutch when slowing the idle would be to high
89stang1 is offline
post #31 of 76 Old 06-26-2009, 02:20 PM
badloser's Avatar
Trader Feedback: (53)
very nice numbers I am sure the car is fun to drive
badloser is offline
post #32 of 76 Old 06-26-2009, 02:22 PM
lone sailor's Avatar
Trader Feedback: (38)
Get the car dyno tuned and then leave it the hell alone. Best two decision you'll ever make.
lone sailor is offline
post #33 of 76 Old 06-26-2009, 02:41 PM
Where are you getting the 12rwhp from? Either way, with a tmoss port job / cam upgrade the 300RWHP is not out of reach.
post #34 of 76 Old 06-26-2009, 03:27 PM
Brian47's Avatar
Thanks,
Mid 12s shouldn't be tough with that power. NED is also faster than LVD from my experience.
Brian47 is offline
post #35 of 76 Old 06-26-2009, 04:36 PM
Thanks!
curious....what does your car weigh?
Tags
gt40 head stock cam dyno
