Junkyard Horsepower SUMMARY! - Page 5 - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
post #141 of 232 Old 10-21-2009, 10:27 PM
aluminum block
Please PM Me and let me know asap please
2VTerror04 is offline
post #142 of 232 Old 10-28-2009, 12:18 AM
needsboost's Avatar
Originally Posted by 2VTerror04 View Post
I have an aluminum block thats reads RF-F2LE i was told it was a teksid block good for about a 1000HP is that correct or do i have a junk block im planning on throwing some twin turbos on it just want to make sure this block will hold up
Thanks Guys
From what I can tell you have a 96-97 teksid. I know that the valleys are different between the teksid & the WAP (99-01). You may want to check out the sean hyland 4.6 book just to make sure.
93 ex-4cyl coupe
needsboost is offline
post #143 of 232 Old 10-28-2009, 09:14 PM
Mr. Kelley's Avatar
Does anyone know about Fuel pumps? I thought I read somewhere that good, high flow fuel pumps, made by Ford, for some newer vehicles, like a Focus etc., can be found in the junk yard.
Or, if not in the junkyard, maybe they would be cheaper at the parts store than buying a "high performance 155 lph" fuel pump from an aftermarket company.
Clint
'90 5.0 LX Florida Highway Patrol "Interceptor"
'67 GTA 390 - Work in Progress
Mr. Kelley is offline
post #144 of 232 Old 12-15-2009, 10:01 PM
Satistraction's Avatar
Clint
anyone??????
1971 Bronco
2004 Cobra
Satistraction is offline
post #145 of 232 Old 12-16-2009, 01:33 PM
i only get 255lph pumps when i do a replacement. newer cars (>10yrs old) are also hard to come by at most pick a parts as well. iirc, only the focus svt had upgraded pumps.
src="/forums/images/smilies/salute.gif" border="0" alt="" title="Salute" class="inlineimg" /> visit my sponsors!
kockyproducts.com KumhoUSA.com idahospeed.com
paintguys.com/paint_sprayboise.htm www.artsperformanceparts.com
stormy69 is offline
post #146 of 232 Old 01-14-2010, 04:21 PM Thread Starter
slo5oh is offline
post #147 of 232 Old 01-31-2010, 01:12 PM
Trader Feedback: (89)
just wondering if someone on here can tell me if a starter on a 94 mustang 3.8 is the same thing as a mini starter described on first page and if so will this work on a 5.0 ????
1994 GT/Fobra clone: 418W coming soon
TVTTFMF'ers
colz89gt is offline
post #148 of 232 Old 02-01-2010, 03:50 PM
yes and yes.....
stormy69 is offline
post #149 of 232 Old 02-01-2010, 06:31 PM
goatnipples2002's Avatar
Trader Feedback: (22)
Kenne Bell only tested the Focus SVT pumps to be 217lph. The 03-04 pumps flow a little more than the 01-02 pumps.
goatnipples2002 is offline
post #150 of 232 Old 02-24-2010, 12:57 PM
Anybody know if an '09 PI Crown Vic still has a usable aluminum driveshaft? I read somewhere that for a few years the PI was using some sort of composite driveshaft...did Ford switch back to the standard aluminum for cars built in the last year or two?
lotzatoys is offline
post #151 of 232 Old 03-09-2010, 02:17 AM
delz05's Avatar
Any gas tank and fuel pump interchange info???
delz05 is offline
post #152 of 232 Old 03-18-2010, 01:36 PM
acline's Avatar
great write up
1992 Mustang GT, T5 WC with Short Throw, ON3 67mm turbo kit, 42 inj, 255 pump, King Cobra Clutch, FRPP Fywheel, and 3.73's, BBK 70mm TB and EGR, Cervinis Ram Air, Stalker FR bumper, Mark VIII Fan, Team Z Adj. Lowers
acline is offline
post #153 of 232 Old 03-18-2010, 08:21 PM
I got explorer type injectors out of a 94 cougar with a 4.6, I also saw them in a 97 towncar.
jling is offline
post #154 of 232 Old 03-18-2010, 11:59 PM
metalman302's Avatar
Trader Feedback: (173)
Is the yoke that comes on the Aerostar DS the correct one for T-45 and 3650?
metalman302 is offline
post #155 of 232 Old 03-19-2010, 12:15 AM
Super Moderator
Ehardy1971's Avatar
If it's the A4LD tranny, no.
'89 LX Coupe
GT40 306 with a few bolt ons and in the 12's
'01 Lightning
#6257 of 6381 Bolt ons, pulleys, and tuned.
'06 TBSS
K&N drop in, and Borla dual exhaust, for now.
Ehardy1971 is offline
post #156 of 232 Old 04-10-2010, 03:07 AM
needsboost's Avatar
Auto-dim rearviews & trip meters? These would be nice upgrades for a daily driver. Thanks
93 ex-4cyl coupe
post #157 of 232 Old 04-11-2010, 05:23 PM
On the aerostars that DO have the correct T5 yoke, do those use the same U joints as mustang?
post #158 of 232 Old 04-11-2010, 05:24 PM
If you want poor man's spark plug boot protectors, you can swipe a bunch of the thermal socks on egr piping.
I use one to shield my wideband wires where they run over my x pipe.
post #159 of 232 Old 04-11-2010, 06:09 PM
nice
stormy69 is offline
post #160 of 232 Old 04-11-2010, 07:55 PM
vinnietbird's Avatar
Trader Feedback: (130)
It cost a little,but cheaper than buying a custom shaft from a company...I got a Crown Vic cop car aluminum driveshaft for free,and spent $108.00 to have it shortened,balanced,and they also installed my yoke and flange with adapter u-joints.Not a bad deal,and it's been great.
Also,compass mirrors from a couple of Cadillacs for $5.00 each (very easy to wire up),and remember whenever you see a 5.0 anything,grab the water pump bolts if they are in nice shape.They actually have a value to them,and they are free at the yards I go to.
'88 Tbird..Z-Spec T-5,GT-40 by TMoss,BBK CAI,Ed Curtis cam,Trick Flow heads,1.6 Scorpions,MSD Dist.,3G,Mass Air with 24's,70mm t-body,BBK CAI,140 mph speedo,8.8 with 3.55's,BBK shorties,mini starter,O/R H-Pipe, Flowmasters,Deep n deeper Cobra R wheels,Taurus fan,CHE control arms
vinnietbird is offline
post #161 of 232 Old 04-14-2010, 03:06 PM
rab
i just skimed thru this quick will read more later, i remember reading the old post a long time ago.
also you can use ranger front rotors with mustang bearings iirc for a cheap 5 lug swap, iirc it was 82-94ish.
rab is offline
post #162 of 232 Old 05-28-2010, 08:22 PM Thread Starter
You can use lots of different years/makes front 5 lug rotors, but IMO I'd rather have a nice NEW set of rotors when you can get decent OEM looking ones for ~$30 each. I'm fine with LOADS of used parts, but rotors and brake pads are one of the few things I won't go THAT cheap on. I used new Mark VII rotors on my '87 and they lined up perfect to the existing GT brakes. Doing it all over (on an 86 4 cylinder conversion) I'm still not sure where I'll go, but I think I'll just convert it all over to SN-95 and be done.
slo5oh is offline
post #163 of 232 Old 06-04-2010, 05:19 PM Thread Starter
I just realized I'm missing a "Convert to a 351" section...
Anyone care to help?
slo5oh is offline
post #164 of 232 Old 06-06-2010, 01:42 AM
needsboost's Avatar
That would be awesome! Block, deck height, roller/ non-roller, oil pan, serp. belt conversion, rotating assembly, & mount info please.
93 ex-4cyl coupe
post #165 of 232 Old 06-08-2010, 08:11 PM
1BAD6T6's Avatar
Since I just did the 351w thing, guess I can pull that info together too.
1966 Mustang Coupe
1993 Coupe - LM7, pt88, th400, MS3x
1995 GT - 100% Stock (emissions and all)
1BAD6T6 is offline
post #166 of 232 Old 06-25-2010, 02:03 AM
wrksnfx's Avatar
For those of you using those high torque starters or the old ones w/ the solenoid on it to keep you from having starting issues due to high heat temperature which causes you to have to lay on the ground and SMACK the starter to get your cars to start for your 5.0's and 5.8 and any others take and do what is shown in the following (pdf) w/ junkyard or new parts painlessperformance DOT com/Manuals/30203.pdf <--- sorry I'm not allowed to post links so just replace the word DOT w/ a . and remove the spaces and it will solve that problem with the solenoid getting so hot from being COOKED by the exhaust manifold just get the solenoid off the fenderwell of any old Ford and Chrysler's from the I believe the 60's, 70's, 80's and mid 90's 3 or 4 pin it doesn't matter just remember which small pin on the 4 pin model which goes to the ignition or just buy them new they are WAY cheaper for a ford at the auto parts store 10 bucks maybe less depending on your local (bandits) racers do this just go and make your own kit that's why I HATE those starters.
Side note:Where it says ballast resistor use a condenser instead it's cheaper and will last a hella lot longer (it's a little metal block with two little bolts and comes w/ two nuts you just use two eyelets crimped on to the wire between the solenoid and the coil this will silence any radio noise too.
wrksnfx is offline
post #167 of 232 Old 06-25-2010, 04:35 AM
Tanus's Avatar
subscribed, thanks for the info
90LX, systemax kit, Z-cam, 175hp nos kit
*Disclaimer*- everything said or seen above is for novelty purposes only. use/repeat at your own risk
Tanus is offline
post #168 of 232 Old 06-25-2010, 01:38 PM
fordjunky's Avatar
Originally Posted by wrksnfx View Post
For those of you using those high torque starters or the old ones w/ the solenoid on it.
To keep you from having starting issues due to high heat temperature which causes you to have to lay on the ground and SMACK the starter to get your cars to start for your 5.0's and 5.8 and any others, take and do what is shown in the following (pdf) w/ junkyard or new parts
www.painlessperformance.com/Manuals/30203.pdf
It will solve that problem with the solenoid getting so hot from being COOKED by the exhaust manifold, just get the solenoid off the fender well of any old Ford and Chrysler's from the I believe the 60's, 70's, 80's and mid 90's, 3 or 4 pin it doesn't matter just remember which small pin on the 4 pin model which goes to the ignition or just buy them new they are WAY cheaper for a ford at the auto parts store 10 bucks maybe less depending on your local (bandits) racers do this, just go and make your own kit, that's why I HATE those starters.
Am I wrong but isnt that the way the 93 mustang stock mini high-torque starter is wired stock??
(I havent had any trouble with my 93 stock mini high-torque starter since I converted from the non high-torque starter back around 2000 & have been running long tube headers)
(Ive seen some guys that they dont rewire correctly for the 93 model starter after they converted & have the starter dragging a moment after the engine fires up)
fordjunky is offline
post #169 of 232 Old 06-25-2010, 02:37 PM
i dont know about 93 specifically (but can check) but thats not exactly the way ford did it on prior years but is how i did it on my earlier cars when i swapped to a mini starter
stormy69 is offline
post #170 of 232 Old 06-25-2010, 05:48 PM
wrksnfx's Avatar
Ford did place a heat shield between the starter and the block for this reason my brother as a mechanic would remove these heat shield and NOT replace them when a car would come into the garage when a customers car needed a new starter just because it was slightly difficult to put back up.
wrksnfx is offline
post #171 of 232 Old 06-25-2010, 06:07 PM
fordjunky's Avatar
This is all I know-
When converting to the 93 high torque mini starter on pre 93 mustangs,
You just take the large cable (comes off the starter & connects to the solenoid)
& swap posts on the solenoid (power side).
Then run a new wire (10-12 gauge or so) off that large post (the 1 that has nothing on it now) & run down & connect to the solenoid on the side of the starter (most of the time theres a male spade on that solenoid)
post #172 of 232 Old 06-25-2010, 06:09 PM
i was confused as i have seen the mini starter on 92's as well..... and the oe wiring did not jump from the battery power to the relay side but had a seperate wire run from the solenoid to eht relay side of the starter....
stormy69 is offline
post #173 of 232 Old 06-25-2010, 06:12 PM
wrksnfx's Avatar
This is all I know-
Ford replaced the spade plug end version with a bolt version which keeps a better electrical connection this is the better one to get but if you must have a starter now and that's all they got then fine.
wrksnfx is offline
post #174 of 232 Old 07-07-2010, 02:20 PM
gonemad's Avatar
why is thread not sticky again?????
gonemad is offline
post #175 of 232 Old 07-08-2010, 12:29 AM
I'm gonna say that's a myth...... redundant series'd soleniods supposed to prevent problems, but wiring it just like a factory 94 95 car with only the solenoid on the starter will cause problems? BS I say.
Just like how ONE guy ages ago put a 96 straight rod booster with fox pedals and *thought* it *might* have caused binding.... and now ever since then, this has been considered gospel on the forums. BTW myself and others have a 96 pedal on a fox booster so same degree of misalignment..... no problems.
