Guys who have bought/experienced fordstrokers.com - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 08-01-2008, 12:20 PM Thread Starter
Question Guys who have bought/experienced fordstrokers.com
Hey guys, I have been searching for stroker engines from different places like T&L, DSS, and Blueprint Engines and have found that they have had bad reviews, I even found where ford racing crate engines had some trouble. But I havent herd anything BAD about fordstrokers.com and their engines. They seem to be dedicated to "what you want" and have great communication and care about what they build. I have tried to email them but it just isn't working for some reason.
What have been your experiences with them?
I know they have 331/347/408/418/427 strokers
I was going to talk to him about a 331 possibly a 347 since they build them with the 5.315 rods
reed95 is offline
post #2 of 5 Old 08-01-2008, 12:48 PM
get the 347 if you are going to do it. There is no reason to leave 20-25 hp on the table going with the 331......
Her name is white lightning. She's loaded with some Griggs stuff, and a plant woody built for me.
onefastsvt is offline
post #3 of 5 Old 08-01-2008, 12:52 PM
duffman's Avatar
great prices, parts and service. Give Jim a PM aka "strokeme" on this forum.
90Cobra,10.3-1, 408W,4340 steel crank,H-beams, SRS pistons,AFR 205,Vic Jr,FTI solid roller,Prosystem 950,1 3/4"LT,3",G-Force T-5,31 spline,3.73
duffman is offline
post #4 of 5 Old 08-01-2008, 02:31 PM
vristang's Avatar
Jim is GREAT to work with.
He is VERY busy though... give him some time to get back to you.
He will.
jason
- jason
1990 GT - something 351w based... some day
vristang is offline
post #5 of 5 Old 08-01-2008, 04:24 PM
Joel5.0's Avatar
Top notch...... have purchased (for my customers).... a 347 stroker kit, 2 balancers, a Liberator 347 SBF and a 408 stroker kit is next.
ACRONYMS:
LUK=Let Us Know, GL=Good Luck, LMK=Let Me Know, JIC=Just In Case, BTSTDTRT=Been There Seen That Done That Repaired That, YCYDYP=Your Car Your Dough Your Prerogative and the classic... DILLIGAS=Do I Look Like I Give A S***
1986 Mustang GT w/T-Tops
NOW: 5.0L Stock shortblock, X303 Cam, SP Offy. Port-O-Sonic, 700 cfm DP Holley, 289 '66, 1.7 RR, Richmond Gear 4+1 Trans., Centerforce DF kit, 2.73 Gears
WIP: 3.90 Gears(Motive Performance), LS Overhaul (FRPP), Adj. LCA's (New Design Granatelli Aluminum), Adj. UCA's (Granatelli), Caster/Camber Plates (MM), Subframe Conn. (MM) T-Top weatherstriping and rear braces bodywork
Joel5.0 is offline
