flywheel bolts...blue loctite or thread sealer? - Ford Mustang Forums : Corral.net Mustang Forum
Old 07-21-2008, 12:07 PM   #1
GTmustang00's Avatar
When installing my flywheel bolts, should i use blue loctite or thread sealer? Then torque to 85 lbs?
Also, what is the torque spec on the pressure plate bolts?
__________________
98 Chrome Yellow cobra 9800 miles
1989 Mustang GT, modified to hell
GTmustang00 is online now
Old 07-21-2008, 12:15 PM   #2
1trkpny95's Avatar
Trader Feedback: (41)
I use the gray RTV sealant on my flywheel bolts. Pressure plate to flywheel bolts should be torqued to 12-24ft-lbs
__________________
2003 OW Cobra Coupe: 2.76 billetflow pulley, JLT CAI, Bassani catted X, Mac catback 470/483
1trkpny95 is offline
Old 07-21-2008, 01:27 PM   #3
I use RED loctite.
rstoff is offline
Old 07-21-2008, 04:31 PM   #4
93mustank's Avatar
Trader Feedback: (113)
Originally Posted by rstoff View Post
I use RED loctite.
+1
__________________
www.FoxBodyPerformance.com - www.facebook.com/FoxBodyPerformance
93mustank is offline
Old 07-21-2008, 05:48 PM   #5
DuffManRHA's Avatar
yea you should be using some type of loctite, i used blue when i did it recently. thread sealent will stop oil, but so will loctite and you know that they ain't gonna back out... especially if you use red (ask me how i know)
Eric
__________________
My Want to Buy list : http://dbdragster.com/wtb.html
'99 Cobra - #256 of 4055
'88 LX 5.0 - Deceased
DuffManRHA is offline
Old 07-21-2008, 06:00 PM   #6
cobraman1024's Avatar
Trader Feedback: (60)
has anyone actually had their flywheel bolts back out on them after torqueing them to the proper 85ft.lbs?
I didn't use any kind of loctite or sealer when I put mine back on. I do have a new special type of rear main seal so I'm not worried about oil leakage through the threads.
__________________
-1995 Cobra #182 of 4005; 275hp/ 305tq, 221k miles, export tails/mirrors, etc
-1996 Mystic Cobra #1666 of 2000; 308hp/304tq, ARH L/T & X, IMRC deletes, Mezeire, LMAF, JLT, MM suspended, 194k miles
-1993 Mustang LX, 2.3L w/ T5 conversion, SN95 suspension w/ 8.8, 03 Cobra steering/brakes, 263k miles
cobraman1024 is offline
Old 07-21-2008, 06:02 PM   #7
Thriller8's Avatar
No mine have never backed out.
__________________
X275 build in progress follow on Mustang Junkies.net
http://www.mustangjunkies.net/f9/project-dirty-red-444
Thriller8 is offline
Old 07-21-2008, 09:59 PM   #8
i used thread sealer this time around, last time i used blue loctite. ill see if they back out or not.
__________________
Old 07-21-2008, 10:18 PM   #9
Trader Feedback: (22)
I did not use anything and had no problems.
Modular is offline
Old 07-22-2008, 08:06 AM   #10
swinerton's Avatar
Be careful guys using Red Loc-tite. The only time I use red, is when I know I will never have to remove a nut/bolt from something ever. 242 Blue works for just about anything.
__________________
Cory Swinerton
2013 Boss 302 #540 712rwhp/592rwtq
Originally Posted by WhiteLX408 View Post
Running street tires at the track is like wiping your ass with a turd.
swinerton is online now
Old 07-22-2008, 08:23 AM   #11
blue here.
95BadBird is offline
Old 07-22-2008, 09:21 AM   #12
How does your "special" rear main seal keep oil out of the threaded holes that go all the way through the crankshaft flange?
__________________
70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, Holley 650 DP, long headers), T5Z w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles.
bmcdaniel is offline
Old 07-22-2008, 09:41 AM   #13
PeteCleary's Avatar
Ford supplies new flywheel bolts with sealer pre-applied. Just a fyi...
PeteCleary is offline
Old 07-22-2008, 10:01 AM   #14
StarrMan's Avatar
I'd like to know too
__________________
In Loving Memory, My Son, Anthony Michael Starr 08/14/2007 - 01/21/2008
- 95 GT - Aluminum Heads, Cam, TMoss Cobra intake, S-trim, SCT BA2400, 55's, Longtubes, McLeod bell, TKO-600, 3.55's, etc
- 02 GT (Wife's Toy) - Auto, 4.10's, Lowered, Off Road X, Predator Tuner - 13.6@102
StarrMan is offline
Old 07-22-2008, 12:55 PM   #15
DuffManRHA's Avatar
since we're on the topic, what you all use for the DS bolts? For some reason, mine continually back out, and I have tried blue loctite and tightening those ####ers down TIGHT. Do you guys use red loctite on this, or a lock washer?
Or am I the only one
Eric
__________________
Old 07-22-2008, 01:16 PM   #16
Trader Feedback: (32)
ive used a lot of blue and tightened them with impact, then tighten them again in a few days.
88junklx is offline
Old 07-22-2008, 03:55 PM   #17
x2
89llx is offline
Old 07-23-2008, 12:27 PM   #18
hsejyrtdr867's Avatar
I used red Loctite with ARP bolts.
hsejyrtdr867 is offline
Old 07-23-2008, 01:17 PM   #19
1trkpny95's Avatar
Eric
Red loctite on the D/S bolts.
__________________
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
