347 lifter problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-28-2008, 09:57 PM Thread Starter
347 lifter problem
ok i have a 92 lx hatch. 347 stroker all eagle stuff. Twisted wedge heads, anderson n-91 cam with the hi-rev springs. drivin it home i started hearing a noise, perty good size tap/knock. too fast to be a rod. i put a new set of comp lifters in it, and it fixed then noise, but now i can't get the valves to set. you can set one side so it's quiet but by the time you set the other side, the first side is tappin it's ass off. it's a consistent loud tap, reviing it up quiets it down some. but it seems no matter how many times i set the valves it's still got a loud tap. and no it's not a normal noise, i know it's not going to have a quiet valve train, but it seems almost that somethin is causin em to be out of adjustment. are the springs and cam too much for stock lifters? or do i have other issues? i don't have a mechanical oil gauge but pressure is great on the stock gauge. still runs and drives great, pulls like a bitch, i raced my buddie in his 11 sec ls1 and pulled on him, so the car still has great power but still at an idle has this very loud and noticible tap/knock coming from the top end of the motor. any ideas? i've been told i might need to just put solid roller lifters in it.
spark plug is offline
post #2 of 4 Old 06-28-2008, 10:30 PM
331-stang's Avatar
my 331 w/a comp cam does the same thing ..no matter how many times i adjust them they keep making noise , i called comp and they told me that it was normal to hear the valvetrain with the engine runnning and the hood open ...but should be quiet with the hood close and sitting in the car ..if that helps ya ..
331-stang is offline
post #3 of 4 Old 06-28-2008, 11:07 PM Thread Starter
i'm not expecting it to be quiet. but this is not a normal valve train noise. i can hear it in the car idling. def a distinctive tap. perty loud. i pulled into a car show earlier and someone asked me if i had a rocker loose or something. it just does not sound right.
post #4 of 4 Old 06-29-2008, 12:09 AM
jkrahn's Avatar
Wouldn't be a rocker touching the inside of the valve cover/oil baffle?
347 AFR 205's, TMoss Vic 5.0, Rawls cam, Tremec 3550.
jkrahn is offline
