How to change rear main seal? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 05-24-2002, 04:46 PM Thread Starter
StangLX302's Avatar
Question How to change rear main seal?
I already have the trans out. I am getting some work done on it. So, I figured while it's out, I might as well put a new rear main seal in. It leaks just a little bit.
I know the flywheel has to come off. No problem there. My question is, how do you get the seal out without removing the oil pan or rear cap?
1988 Mustang LX Hatch
331 Stroker, 10.4:1 Comp., World Windsor Jr. Heads, XE282HR Cam, TFS 1.7 Rockers, Victor Jr Intake, Demon 650 Carb, MSD, 3" Hooker Max Flow Mufflers, Manual VB AOD w/Transbrake, 3200 stall, 4.10 Gear, Weld Draglites, Manual Rack, Drag Suspension, 4" Cowl Hood, Fiberglass Hatch
StangLX302 is offline
post #2 of 7 Old 05-24-2002, 08:23 PM
I drilled 2 small holes in the seal straight across from eack other, put two small sheet metal screws into it and used two pairs of plyers and wiggled it right out!! Its fairly easy!!
MODS:
Edelbrock Aluminum RPM Heads, Harland Sharp 1.7 Roller Rockers, Trickflow Stage 1 Cam, Trickflow Track Heat Intake, Edelbrock 70mm TB/EGR, Pro-M 75mm MAF, FMS 24# Injectors, Aeromotive Adjustable FPR, FMS 9mm Wires, AC Delete, Smog Pump Delete, Walbro 190 gph Fuel Pump, Melling HV Oil Pump, FMS double Roller Timing chain, FMS Roller Lifters, ARP Head, Intake, Flywheel bolts, Felpro gaskets, FMS 3 Core Radiator, Perma Cool Electric Fan, Under drive Pulleys, 180 degree thermostat, BBK Cold Air Induction, Electric fan, Trunk Mount Battery,PA Reverse Manual C-4, PA 3200 Stall converter, Cheetah Shifter, FMS Aluminum Driveshaft, FMS 373 Gears, MSD 6AL, MSD TFI Coil, MSD Pro Billet Distributer, A9L Computer, Custom burnt Autologic chip, Kenny Brown Strut Tower Brace, Adjustable Crossmember, D&D Subframe Connectors, Energy Suspension Poly Motor Mounts, Energy Suspension Poly Transmission Mount, BBK Unequal Length Chrome Headers, BBK Off Road H-Pipe, Flowmaster 2 Chamber Cat-Back, Zex Nitrous Kit, ZEX Remote Bottle opener.
2001 Lexus RX300
1975 Mercedes 480SL Convertible, 2 seater Roadster (FOR SALE)
1989 Lincoln LSC Mark VII (FOR SALE)
NOS89GT is offline
post #3 of 7 Old 05-24-2002, 08:24 PM
With a seal removal tool (little flat tool with 2 points on the end). Some people use a screwdriver. Try whatever just don't damage anything or you'll never get it to seal right.
Greg
2012 Hyundai Sonata 2.0T SE (stock 14.443 @ 97.32 ~1900' DA)
211whp (stock)
mustanggreg is offline
post #4 of 7 Old 05-24-2002, 09:00 PM
ersunl's Avatar
argh....Ford rear mains!!!
I've heard from a lot of people that it can be a bit of a gamble. If you're changing it to get rid of the un-avoidable ford rear main oil leak, I hear it's about 50/50 in fixing it. I've also heard that your old seal is worn to shape and replacing it can even make the leak worse. This is just what I've heard. Next time I have the tranny out I'd like to try it to... a few drops of oil every time I park it...it's a real pain in the butt.
Good luck
-Eric
- Eric -
'91 Mustang GT
ersunl is offline
post #5 of 7 Old 05-24-2002, 09:09 PM
Niks90coupe's Avatar
I'm changing mine tomorrow, let me know how yours goes StangLX302
Nik
Niks90coupe is offline
post #6 of 7 Old 05-24-2002, 09:23 PM Thread Starter
StangLX302's Avatar
Thanks everyone for the input. I am going to change it sometime this week-end. I'll let you know how it went.
BTW: Is that a really common thing to go bad on a 302? The one that is in there right now only has 7,000 miles on it.
post #7 of 7 Old 05-25-2002, 12:52 AM
Well ersunl said it right, about 50/50.
I changed mine on my old '91 GT when I put a tremec and it stilled leaked. Oh well, as long as its not too bad, than just make sure to check your oil every once in a while.
Greg
211whp (stock)
