Cobra Intake vs. Stock Intake - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 59 Old 03-11-2008, 06:57 PM Thread Starter
I was thinking of ordering a Cobra Intake Upper/Lower. And was wondering if there is how much performance increase over the Stocker???
jermdawg is offline
post #2 of 59 Old 03-11-2008, 07:05 PM
90 LX TC's Avatar
Trader Feedback: (53)
a good bit..as the major restriction in the stock set-up is the lower...why not save a 100-150 bucks and get a Explorer set-up??? same thing and they look better IMO. run one on my car.
90 LX Fully Built 2.3T88GT 302400RWHP/402RWTQ
Scoupe89 is a idiot/doesnt know what the hell he is selling. Buyer beware!
90 LX TC is offline
post #3 of 59 Old 03-11-2008, 07:07 PM Thread Starter
Don't know much, actually haven't read up much on the Explorers. I guess I will have to look into them. THANKS
jermdawg is offline
post #4 of 59 Old 03-11-2008, 08:13 PM
Michael Yount's Avatar
Cobra/Explorer/Mountaineer/GT40 tubular all share the same lower -- and as with the stocker, it's the flow restriction, so they all perform about the same.
Michael Yount is offline
post #5 of 59 Old 03-11-2008, 08:44 PM
90 LX TC's Avatar
and just to clear it up stock mustang lower puts out around 130-140 cfm while stock GT-40 style put out around 190-205cfm...stock heads flow around 160ish CFM...so with that intake the heads become next in-line for the restriction.
90 LX TC is offline
post #6 of 59 Old 03-11-2008, 08:54 PM
....and, if you're not gonna replace the heads, the more economical approach is to have tmoss port the stock lower - he can take it up to around 180-190 cfm....
post #7 of 59 Old 03-11-2008, 10:02 PM
$uperstang's Avatar
Better yet get yourself the gt40 based intake with a tmoss port job and have it flowing 240-250cfm.
1990GT - AOD
325ci Stroker
11.85@116 NA with Drag Radials
1.59 60'
$uperstang is offline
post #8 of 59 Old 03-11-2008, 10:27 PM
MFE
Super Moderator
MFE's Avatar
Putting a Cobra intake, 65mm TB, and 75mm MAF on my stock 5.0 top and bottom end, with nothing else installed prior other than shorties, pulleys, K&N, cat-back and 3.55's, netted me a solid and infinitely repeatable 3-4 tenths and 3-4 mph in the 1/4.
MFE is offline
post #9 of 59 Old 03-11-2008, 11:15 PM
tmoss's Avatar
Trader Feedback: (47)
there is a lot of info on this subject on my website - spend some time reading in the tech section.
Tom Moss
tmoss is offline
post #10 of 59 Old 12-09-2008, 02:39 PM
hypersurf1's Avatar
What is your website? I recently got an 88 vert im looking to put some more power into N/A and on a budget. Thanks.
2007 Shelby GT, Paxton 2200 SL, 4.10's, 499RWHP 440RWTQ
hypersurf1 is offline
post #11 of 59 Old 12-09-2008, 03:04 PM
DangerWillRobinson's Avatar
Trader Feedback: (46)
The GT40 intake setup helped me lay down 246/300 at the wheels. It's A BIG difference from stock.
DangerWillRobinson is offline
post #12 of 59 Old 12-09-2008, 03:04 PM
How much does a tmoss port job run anyway? I cant see his sight.
post #13 of 59 Old 12-09-2008, 04:16 PM
or you could get the holley systemax I lower...
http://www.gofastnews.com/board/tech...ranteed-2.html
my personal site thatmetalbox.com
Hamutoff is offline
post #14 of 59 Old 12-09-2008, 05:30 PM
hypersurf1's Avatar
how would explorer GT40 heads/intake ported and polished, with 70mm bbk TB, and comp cams 1.7 rocker arms wake up a stock 1988 GT?
post #15 of 59 Old 12-09-2008, 05:44 PM
You'll notice it! Without the heads I made some impressive numbers and the car feels MUCH better. It's completely different car at the top of the rev's now.
post #16 of 59 Old 12-09-2008, 05:52 PM
Be aware that the Cobra intakes are now made in China and have had issues like excessive oil burning,distributor clearance problems,poor casting quality.
I would try and find an original made in USA Cobra instead of the made in China junk version or use a lower cost Explorer intake.
8950HO is offline
post #17 of 59 Old 12-09-2008, 05:56 PM
hypersurf1's Avatar
Did you have to do anything special to get the intake to work? I see some have had to drill into the manifold for some reason.
post #18 of 59 Old 12-09-2008, 07:37 PM
Trey LePark's Avatar
It's kinda pointless to send someone looking for something that is impossible to find. Holley only made a few of those lowers and they're harder to find than a glacier in the Sahara desert.
'92 5.0 5 speed
Trey LePark is offline
post #19 of 59 Old 12-09-2008, 10:53 PM
tmoss's Avatar
my website is down indefinately - that post referring you to my site was done last March. My Webmaster/Site Host lost his business and my site had to come down.
Budgets mods would be to port your lower intake and get the Stock HO intake to flow in the 200cfm range or get a used Explorer that flows the same in stock condition to use- but they do trake some minor mods to work if you get a 96 Explorer intake. I have three 96 Explorers with internal EGR like the stock HO intake if anyone needs one.
Take a look at my sig for the power I got from these parts.
Tom Moss
tmoss is offline
post #20 of 59 Old 12-10-2008, 02:44 AM
really, how many did they make then?
Hamutoff is offline
post #21 of 59 Old 12-10-2008, 02:52 AM
on a stock 5.0 the cobra might not be the best possible upgrade for a DD even though other intake combos might be even worse
This thread talks about it..
Trickflow vs. Cobra intakes on a stock motor
Just proves that on a mild 5.0, even the Cobra intake is too much and causes a loss of torque below 3500rpm. A Tmoss ported stock intake would be better on a stock-headed, stock cammed 5.0 until it's time to upgrade those items. With better-flowing heads, the Cobra intake (Tmoss ported of course ) would then be a great mod.
and back to my eariler suggestion if we're not talking extreme engine perhaps mild/stock as I am simply guessing... the upper might be ok for you then the lower is the restirction sure port lower is a good suggestion or get the systemax I lower, I JUST BOUGHT A NEW ONE MYSELF from a www store, and they come up on eBay though they have not been made for a few years: YES true, but neither have gt40 irons, gt40p, or 5.0 fox mustangs for that matter, etc.
Hamutoff is offline
post #22 of 59 Old 12-10-2008, 02:58 AM
...get an Explorer...Seems to have a little less low end than my previous cars with an extended powerband compared to my other cars....which were essentially the same but without the intake and with less weight. So the other cars seemed just as quick with less mods
z28freak84 is offline
post #23 of 59 Old 12-10-2008, 05:06 AM
302EFI's Avatar
Trader Feedback: (23)
LOL...thats not that much considering a stock HO motor is 225/300..even though thats at the flywheel...
" Do the world a favor & drive this peice of junk off a cliff "
302EFI is offline
post #24 of 59 Old 12-10-2008, 05:12 AM
hypersurf1's Avatar
thats about 75rwhp more then stock. ford corrected the rating of the 88-93 mustangs to 205HP, the 225 number was overinflated and done to sell cars. using 205hp that would be about 174rwhp stock for a manual trans. so hes about 75rwhp higher, a pretty good improvement for minimal cash outlay. That is actually awesome considering he never cracked open the heads I would assume with some GT40 heads he would be around 275rwhp.
post #25 of 59 Old 12-10-2008, 05:16 AM
302EFI's Avatar
Thats not really minimal cash output with the other mods in his sig
Also I beleive your wrong about your numbers...
88-92 was advertised at 225 HP
'93 was rated a 205 HP (they rated it with accs on to make the new '94 look "better" )
302EFI is offline
post #26 of 59 Old 12-10-2008, 08:23 AM
I don't know but it couldn't have been very many. I've been casually looking for one for about 5 years and I've never seen one anywhere. Do you know where there is one available?
'92 5.0 5 speed
post #27 of 59 Old 12-10-2008, 08:34 AM
Please provide a link to a Systemax I lower for sale anywhere! I have an extrude honed stock upper I'd like to pair it with.
'92 5.0 5 speed
post #28 of 59 Old 12-10-2008, 09:25 AM
The closest to stock my car ever was made 198/242 at the wheels with only an off-road x-pipe dumped.
Then I added the setup in my sig and it made the 246/300. BTW, I bought all the parts used and spent a minimal amount (less than $600).
So I'd say yes you are right sir... for a minimal amount of cash, you can make good numbers. To the OP, I would say it's a good investment if you want some more power. But when you start changing parts, it only gets worse... you wont want to stop.
This weekend I am bolting on a set of AFR 165's and 1.7rr's with a Lunati cam. I hope to hit 300/340 to the wheels now. Got those pre-owned too for a good deal.
post #29 of 59 Old 12-10-2008, 09:49 AM
tmoss's Avatar
on stock E7 or GT40 heads, no EFI intake will make as much torque and power below 4,000 rpm as a ported stock HO intake and it won't loose all that much up to about 5,200-5,500 rpm depending on the cam used.
Tom Moss
tmoss is offline
post #30 of 59 Old 12-10-2008, 11:37 AM
hypersurf1's Avatar
http://auto.howstuffworks.com/1987-1...-mustang11.htm
Dont be an idiot, they didnt magically downgrade the power one year. They over rated it from the get go. You probably dont even own a Mustang, go back to chevrolet world where you came from! Its people like this that make me take Xanax.
"They rated it with the accesories on" are you serious, your not that dumb are you?
Moron!
post #31 of 59 Old 12-10-2008, 01:00 PM
What if porting is not an option due to class rule restrictions (NASA CMC)? I assume the GT40 intake, also stock, would be the better choice with GT40 heads? How badly would the stock HO intake choke the GT40 heads or would that be a decent combo to try? I have both intakes. Currently running stock E7s with a stock SN95 HO upper/lower, stock SN95 exhaust manifolds, stock SN95 MAF, TB, etc. with off-road X-pipe. It makes 225/293 RW on a Dynojet. Looking to make some legal upgrades with the GT40 parts to get into the 250 RWHP range.
Matt King is offline
post #32 of 59 Old 12-10-2008, 01:05 PM
hypersurf1's Avatar
Im pretty sure that an unported gt40 would kill a unported stock intake on the flow bench. Its only when the stock lower is ported that it can compare to the gt40.
post #33 of 59 Old 12-10-2008, 01:06 PM
+1, only I'll take it a step farther. Just MHO, but the cobra intake should not be put on stock heads unless they've been worked over. You lose ALL sorts of TQ to gain maybe 10 hp over 4000rpm. The car will drive better and probably be faster with a stock untouched intake.
slo5oh is offline
post #34 of 59 Old 12-10-2008, 01:22 PM
carrew's Avatar
I saw a new in the box systemax 1 for sale about 2 weeks ago and they wanted $650 . I know it comes with a matched cam, but thats systemax 2 pricing. You could do better and cheaper with a Explorer upper, tmoss lower, and FTI custom cam setup for that combo for about the same money.
explorer manifold - $150-$200
Tmoss ported - $150
FTI custom cam - $300
2014 Camaro 1LE
2001 Cobra White SOLD
1989 Mustang GT "F0xR0d" SOLD
12.49 @ 116.8 mph (BFG KDW Street tire)
carrew is offline
post #35 of 59 Old 12-10-2008, 02:45 PM
tmoss's Avatar
For classes that allow no porting, I would use the GT40 family of intakes over a stock HO.
Tom Moss
tmoss is offline
