390 FE Build-up reccommendations? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > 351C/Big Block Engine Tech
Old 06-24-2005, 10:21 AM   #1
I need some parts reccomendations for a 390 FE engine. My goal is to have a torquey strong engine that has a fast chop / hard hitting musclecar sound on pump gas. Do you know of a camshaft under .550 lift that will do the job and what heads are more desirable? It has the late 50's model 352 heads and edelbrock intake with the 428 cam now but the cam sounds lazy. Thanks
__________________
89 Coupe with 4.6 DOHC 32V, Tremec 5 Seed, 4:30 8.8, S trim Vortech @ 18 PSI.
modularFords.com Moderator
The Ultimate All Modular Website
GettyUp is offline
Old 07-01-2005, 07:08 PM   #2
The F.E. is my passion. I know a fare amount about them,with more to learn. I had a very nice running one until I blew it up. I would be glad to discuss this with you over the phone.I feel we could come up with a nice combination. Please E-Mail me if you would like to discuss. r-jmetzger@verizon.net Richard Metzger
Richard Paul Metzger is offline
Old 07-02-2005, 11:07 PM   #3
90NotchLX's Avatar
Here is my set up that I'm running in my Falcon
390 .030 over. It has Froged Speed Pro Flat top piston. 428 CJ heads ported and polished. I have Hooker SuperComp Headers. Luntia Cam 256 @.50 and .601 lift. Factory Dual plane intake with a 1050 Dominator. MSD 6AL ignition. Moroso 8mm spark plug wires.
__________________
68 Falcon, FE 397ci glide, 9' with 4.56 gears. Broke the 487ci FE.
90 Mustang 69 351W, C6 2800 stall 3.73.
Driver (77 Mustang II) BBF 525ci A460 heads PG trans, Dana 60 rear, 4.10 gears, Full Chassis car
90NotchLX is offline
Old 07-02-2005, 11:11 PM   #4
90NotchLX's Avatar
I have a C4AE-B 427 cam, Lifters, and Push rods that came out of my 406. I want $200.00 OBO for it all. Plus shipping.
__________________
Old 07-06-2005, 09:36 AM   #5
I have a similar cam and it doesn't sound or run too good. It is a NAPA hi-po replacement for the 427 / 428. Don't know much else about it. I didn't build it BTW.
__________________
GettyUp is offline
Old 07-06-2005, 09:37 AM   #6
I have heard that past .550 lift cams, you need shaft end supports, heavier shafts and rockers or breakage will occur. Also I don't want to have piston to valve clearance problems with stock replacement pistons.
__________________
GettyUp is offline
Old 07-06-2005, 09:46 AM   #7
Neat car. What casting number is that intake and is it ported?
Did you have to notch the pistions or were they made for large diameter valves?
__________________
GettyUp is offline
Old 07-06-2005, 12:07 PM   #8
90NotchLX's Avatar
That cam in my old motor 406ci went 12.03@109. It's a nice cam. I didn't even have good heads on the motor. Just 390 heads that were clean up a bit.
__________________
Old 07-06-2005, 12:09 PM   #9
90NotchLX's Avatar
The intake is a Police Interceptor intake and yes it's ported. We had to fly cut the piston a little. I have a Single plane Offen Houser Port O Sonic intake that I want to put on it but Just haven't got around to it.
__________________
Old 07-06-2005, 12:12 PM   #10
90NotchLX's Avatar
Here is a video of my Falcon
http://s40.yousendit.com/d.aspx?id=1...D1HCAEVP0VEMHS
__________________
Old 07-31-2005, 06:38 PM   #11
what about a crane 343941 camshaft and edelbrock rpm intake. Are those late 352 heads big port? if they need work do a little clean up or throw in some decent valves and get some headers. Good 370-400hp and 450tq!
fordeverpower is offline
Old 08-10-2005, 04:42 PM   #12
Check out this site.
http://www.network54.com/Forum/74182
The guys over there are FE fanatics and some of the top guys around. I am personally a dummy, but love the FEs and I have learned a ton about them on that board.
__________________
OkieHog--Ebay 525+ no negs
1967 Fastback, SB, Auto, Dlx Int; 1968 GT, 390 4 Spd Fstbck;1969 Mach 1 CJ, auto, Shaker, fire victim--Need parts!; 93 Teal Cobra
OkieHog is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
