#1 |
If Your A Real Ford Guy...
And you got blue blood runnin thru your veins...
And the only thing that matters in life... Is whoppin them bowtie dudes... Because the..."My Mustang is faster than your Mustang"...thing just doesn't matter... Then here's the puppies you got to beat...for straight line racin anyway... So...whatcha waitin for...
| Sponsored Links | |
Advertisement |
#2 |
Location: Troy,Al, at work, in the shop, or at the track.
The famed SBII heads.
Almost a copy of a C302 head, just with better intake runner/intake valve alignment. The Fords need a two carb intake to get similar alignment. Or maybe, someone like Wilson can pull it off with a single carb intake and a tricky runner design.
__________________
1969 fastback street car project underway. I'm a white, gun owning, hetero, Christian, conservative, male. How else may I piss you off today? Beware of leftist/liberals posing as Americans. |
#4 |
Know thy Enemy...
These are not SB-2 NASCAR heads... The runners are NOT directed to a central mounted single carb... These are the Pro-Stock Truck heads... Designed for 2/4bbl sheet metal tunnel rams... And were down...30-50 hp... BTW...4" deck to intake roof...nice... Last edited by 1BAD50; 11-25-2004 at 05:23 PM. |
#5 |
Kinda funny how it has evenly spaced intake and exhaust ports and angled spark plugs.
Does that sound/look familiar?
__________________
88 coupe, 351 cleveland, unported 4V heads, buddy rawls custom solid roller, diamond domes, 6'' h-beam rods, stock 4bolt block/crank, holley strip dominator, 950HP holley, hoosier 28x10, 90/10s, UPR pro rear kit nonstroked, stock iron heads and NO NITROUS!!!!!!!! 10.08@134.83 / 6.44@108.21 (1/8th) |
#8 | |
__________________
#10 |
part of the problem with the fontana-arias -ford (austin)is because the cylinder and crank spacing is different than the Chrysler based engines....
...at least that is one of the reasons that glendora gave.... |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
