A9L controlling a big block? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-03-2010, 05:36 PM Thread Starter
90 Crustang LX's Avatar
Is there a way to use my stock a9l to run a 460? This is a carbed 460, so I figured i could just drill and tap the intake for injectors and make a throttle body to carb flange adaptor, and get a later fi distributor. What about the firing order? dunno if its the same or not.
1990 Mustang GT, T56, 425ci Windsor, 225AFR's, Megasquirted
1977 Ford F250 408m, 4 speed, 2wd
1972 Honda CB350 Four,
Project: 1931 Model A Ford tudor sedan, rat rodish with 2.3 turbo 5 speed
90 Crustang LX is offline
post #2 of 3 Old 03-03-2010, 08:34 PM
Banned
There is a guy...
Okay, an acquaintance of mine who runs an '86ish speed density system on a couple of 385 series engines,
the trick is using the appropriate sized throttle body and injectors. It works for him, it'll probably work for you...
post #3 of 3 Old 03-03-2010, 08:56 PM
BradleyRJ's Avatar
Trader Feedback: (25)
I think the Mega squirt setup may be a little more user friendly for this type of deal. With the A9L you still have to have a way to tune, change parameters. Using a megasquirt / Fast style stand alone would be much easier I think.
They say what goes up must come down but I ain't reached my cruising altitude.
Take a look at what I did but can you imagine what I'm about to do.
BradleyRJ is offline
