1970 Fastback - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > 351C/Big Block Engine Tech
Old 11-20-2009, 08:37 AM   #1
1970 Fastback
Hey I have a 70 fastback that currently has the stock 302 in it. What will I have to change to swap in a 70 351c. Will all the accessories bolt up from the 302 to the cleveland, or will I have to find new brackets.
pawnman is offline
Old 11-20-2009, 02:31 PM   #2
you will need new brackets, and things such as distributor and exhaust manifolds if your new engine doesn't include those. I believe the motor mounts are the same, but while doing a swap, I would put fresh mounts on anyway.
Your transmission bellhousing will bolt right up, but if if using an automatic, I am fairly certain you need a different torque converter. If it is a manual transmission, I believe the flywheels are the same, but am not certain
Your front springs might be a little light as the 351 is about 60-70 pounds heavier fully dressed, or you could relocate the battery to the rear of the car to offset the weight gain up front.
Consider a monte carlo bar (a curved one will probably be necessary) and subframe connectors (weld in) to keep the body from getting twisted by the extra power.
Jeff73Mach1 is offline
Old 11-20-2009, 05:03 PM   #3
you will have to modify or find new brackets.
62HIGHBOY393C is offline
Old 11-21-2009, 01:11 AM   #4
HEADERS...
most 302 equipped cars came with a 8 inch ford rearend housing...
__________________
I have gone down the road that you are only now about to travel.
tires are the great equalizer
a degree wheel, EIGHT INCH dial caliper & adjustable pushrods should be just as normal as a 1/2" wrench in your toolbox
there aint no shortcuts to doing it RIGHT....
Kato Engineering is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
