460 in a Fox body?? What do I need?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 08-20-2008, 09:48 PM Thread Starter
gtdroptop's Avatar
Trader Feedback: (22)
I have a 85 coupe original V8 car that Im looking at putting a carbed 460 into. What am I gonna need to get to make it all possible? It will be a mainly track only car.
gtdroptop is offline
post #2 of 12 Old 08-20-2008, 11:36 PM
MurPHy4570's Avatar
Engine, trans, motor mounts, trans mount, different length driveshaft (maybe). Since it's carbureted wiring it up will be easy. You can fit it under a stock hood too, if you are careful in your intake manifold and air cleaner choice, and use an aftermarket K-member.
"Our Country! In her intercourse with foreign nations, may she always be in the right, but our country right or wrong."
- Commodore Stephen Decatur, Norfolk, Virginia, April 4, 1816
MurPHy4570 is offline
post #3 of 12 Old 08-21-2008, 10:55 PM
Jay Meagher's Avatar
I hate to say this on a Ford forum...being a Ford guy... But a BBC is really the way to go. You can build a stock crank/rod/trw pistoned/stock casting 454 that will murder a 460. I think someone makes a k member for it and stock Chevelle headers bolt up.
Just a thought.
Please don't PM. Email
Jay Meagher is offline
post #4 of 12 Old 08-22-2008, 12:18 AM
faststang90's Avatar
http://460ford.com/ im doing a 547 with A heads in my 93 this site has alot of 460 mustang info. u can do a chevy motor in it if u want to but they make alot of things to put a 460 in it. my A heads are bbc exahust 2 1/4 x4 headers and i have about 1400.00 in the headers. there is a fw guys on there that run low 10s high 9 with a stock 460 in one. the shop that is doing my motor said that he had done a 557 with my heads and only about 10.5:1 made a lttle more than 1000 hp and i should be a little more than 1100 horserpower with mine being 13.5:1
faststang90 is offline
post #5 of 12 Old 08-22-2008, 01:31 PM
castration of all the B a s 'Tards that put a chebby block in a FORD.....!!!!
just as a stock chebby can be put in...just install the 460 ford.
a stock 460 type block can EASILY be stroked and becone 512 inches... no stock chevy block can do THAT...
either way, and no matter the actual size of the engine, the easier mannor to do the install is with a tubular K member and a motorplate.. because this will allow you to move the engine forward and / or up to create better traction and transmission clearance.
I have done a number of them....
I have gone down the road that you are only now about to travel.
tires are the great equalizer
a degree wheel, EIGHT INCH dial caliper & adjustable pushrods should be just as normal as a 1/2" wrench in your toolbox
there aint no shortcuts to doing it RIGHT....
Kato Engineering is offline
post #6 of 12 Old 08-23-2008, 06:19 AM
Just a thought.
I saw a nice 460 fox build at a shop last week and the owner said he wish hed spent the money on a different motor. He wasnt happy with the results. I didn't question him much but the motor was all decked out with some nice aftermarket stuff.
mine: 2002 SVT lightning, 4lb pulley, predator. (sold)
91 lx 4cylinder...
jfboy is offline
post #7 of 12 Old 09-17-2010, 10:10 AM
im a Big Block Chevelle guy at heart , i have owned a 68' SS and a 72' both with 468ci motors. I wanted another chevelle but they were just too damn expensive now so i picked up my Mustang which was my 2nd choice. If i was gonna build a motor from scratch for my Stang it would be a Rat motor without a doubt. When i met my wife i was in the process of putting the 468 from the 72' chevelle in a tubbed 86' GT , somehow that turned into a House instead
2013 Grabber Blue GT Premium A6 Procharged
9.93@137 10psi
Bubba408str is offline
post #8 of 12 Old 10-14-2010, 12:08 AM
I've got a full int hatch street car with a stock block 545 cubic inch bbf small hyd cam 950 carb running 6.70's at 100 mph with a stock slipping c6 and have 3000$ in the motor
Seems like cheap horsepower to me
big block fox 339 is offline
post #9 of 12 Old 10-14-2010, 08:31 AM
5.0mustang5speed's Avatar
Just a thought.
absolutely totally 100 %
1962 falcon stock 1992 302 short block, RHS heads, 1.5 inch headers ..bullet cam ..victor jr.. 11.56@113mph on 26x8.5 inch slicks with 1962 suspension(under construction getting back halved)
1979 zephyr , 393w, bone stock 1979 suspension on 26-8.5 tires 10.94@121
5.0mustang5speed is offline
post #10 of 12 Old 10-14-2010, 08:38 AM
BBC crank is rated at 450 hp
BBF crank can handle twice that
BBF bock can b made 557 cubes with no problems
BBC can't do that
Il race any BBC on the planet that has been built from scratch with 3000$
post #11 of 12 Old 10-14-2010, 12:50 PM
motor in my falcon was junk as it comes.. bone stock lower end from a early 80 460 f250 truck..stock crank..rods and pistons..oil pump etc... stock dove heads with the correct valve springs on it..did have a mild roller cam in it and a victor intake, stock c6 tranny with a jegs 2800 converter and 3.50 gears ..ran 11.70 , had literately 800.00 in the whole motor -tranny
post #12 of 12 Old 02-21-2014, 08:18 AM
keithnra's Avatar
Trader Feedback: (29)
Cool old thread I found today
89 GT convertible 5.0 GT40 irons BBK 70mm TB,
66 289 bored .40 over Holley 600 comp cam
85 GT with T-tops yeah its rough!
86 coupe with 4 banger 96 GT vert 86 GT
keithnra is offline
